Halon (BCF) fire extinguishers
Chris Wilson
I believe it can still be used in very specialist applications where other fire extinguishers would not be appropriate. But generally yes it's considered a very nasty chemical, and is banned due to it being an ozone depletant.
Exceptions for Usage of Halon Fire Extinguishers
There are only three main exceptions for Halon fire extinguisher usage; in aircraft, military use including vehicles and fuel installations, and in the Channel Tunnel. So, don't worry if you spot a green Halon fire extinguisher on an airplane - it's allowed to be there!
Mike
There may be some around somewhere, but most won't have been serviced in a very long time, would you want to put your trust in an extinguisher when you won't know if it works until you need it?
At the very least keep a CO2 as a back up.
Mike
Just for hand held usage, those in the know berate the MSA for sanctioning lesser extinguishants year on year in a placation of the Greens. I have a smallish Halon hand held, would like something beefier to take out for testing purposes, "just in case" :)
Thanks Mike.
chris it is a health and safety issue , it works on removing the oxygen from the triangle .
triangle being oxygen /heat/fuel , remove any of those and you dont have a fire .
but removing the oxygen is classed as a health and safety issue due to the fact you need to breathe , so even basic fires you dont really want to get BA when theres others that will do the job
never risk your health mate .
I know a couple of the jet mechanics on my base got sprayed with this accidentally (although it probably saved them from massive burns) when something caught fire when doing emergency repairs. I was in the emergency room with them and alot of the EKG's registered them as legally dead, or having multiple consecutive heart attacks and all of them experienced tachycardia and eurythmia for some time after. Not to say it isn't extremely effective when standard extinguishers can't be used. However, it should be handled by professionals I.E. Fire department
It's not for a plumbed in system, just as a hand held in case of underbonnet fire et cetera. It's till the most effective automotive extinguishant.
A quick search seems to suggest the replacement would be "FE-36" http://www.fireextinguisherguide.co.uk/2008/08/04/fe-36-clean-agent/
"not yet widely available in the UK and Europe, these extinguishers are used in medical facilities across the USA"
"In the UK Today
Motorsport participants might also be interested in the Zero 360, an FE-36 extinguisher especially for high performance racing and rally cars from Lifeline."
...but they look like plumbed in systems only.
