JS2004 Posted May 7, 2010 Share Posted May 7, 2010 As the title says really.. I am getting into machine polishing and lots of the guides I am reading make reference to paint hardness. Apparently Hondas have "soft" paint and these are Japanese so by that logic I am thinking Toyota is also "soft" .. but this is just an assumption. Does anyone know for sure where it sits on the scale? Cheers Quote Link to comment Share on other sites More sharing options...
michael Posted May 7, 2010 Share Posted May 7, 2010 Depends on colour but in my experience the flat colours are pretty soft. Quote Link to comment Share on other sites More sharing options...
scotty71 Posted May 7, 2010 Share Posted May 7, 2010 (edited) Soft and when I contacted polished bliss about compounds they advised me as such. Polished bliss's reply, just found the email:) Hi Rob, You're correct in thinking the paint will be soft (unless it's had any re-spray work done with a hard paint/clear coat but it's unlikely as most re-sprays tend to be on the soft side) so the kit ideally suited to you would be the Meguiars G220 Soft Paint Kit (http://www.polishedbliss.co.uk/acatalog/pb-g220-soft-paint-polishing-kit-cat1.html#aMasterZG220SP0 ) or the DAS-6 Soft Paint Kit (http://www.polishedbliss.co.uk/acatalog/pb-das6-soft-paint-polishing-kit-cat1.html ). The DAS-6 one is on back order at the moment but will be with us at the start of January. Edited May 7, 2010 by scotty71 (see edit history) Quote Link to comment Share on other sites More sharing options...
JS2004 Posted May 7, 2010 Author Share Posted May 7, 2010 Its black - sorry I should have been a bit more specific =) Quote Link to comment Share on other sites More sharing options...
michael Posted May 7, 2010 Share Posted May 7, 2010 Its black - sorry I should have been a bit more specific =) Soft. Quote Link to comment Share on other sites More sharing options...
JS2004 Posted May 7, 2010 Author Share Posted May 7, 2010 Alright - It was a good idea to check then as I am sure one of the compounds I have in my kit and was going to try is quite an abrasive cut. I shall adjust my plan accordingly - aiming to improve some of the swirl marks mainly. Cheers guys Quote Link to comment Share on other sites More sharing options...
JS2004 Posted May 7, 2010 Author Share Posted May 7, 2010 http://www.cleanyourcar.co.uk/polishing/polishing-machine/das-6-dual-action-polisher-menzerna-kit/prod_522.html this is the kit I have. Thanks for the bit about resprays Scott - I have an aftermarket bumper and the bonnet was also resprayed so that covered my next questions. Quote Link to comment Share on other sites More sharing options...
colsoop Posted May 8, 2010 Share Posted May 8, 2010 I think the paint hardness is irrelevant. Always start with the least abrasive compound and pad you can get away with to achieve the correction needed. Do a small test panel with the different combos to get the results then use that combo on the rest of the car. Quote Link to comment Share on other sites More sharing options...
scotty71 Posted May 8, 2010 Share Posted May 8, 2010 http://www.cleanyourcar.co.uk/polishing/polishing-machine/das-6-dual-action-polisher-menzerna-kit/prod_522.html this is the kit I have. Thanks for the bit about resprays Scott - I have an aftermarket bumper and the bonnet was also resprayed so that covered my next questions. Snap Quote Link to comment Share on other sites More sharing options...
Paul Posted May 8, 2010 Share Posted May 8, 2010 Mine has had a respray but I machined it with Menzerna products and it came up really well, Final Finish is a great product if worked correctly. I invested in a Chicago Pneumatic rotary too, great tool Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted May 8, 2010 Share Posted May 8, 2010 I think the paint hardness is irrelevant. Always start with the least abrasive compound and pad you can get away with to achieve the correction needed. Do a small test panel with the different combos to get the results then use that combo on the rest of the car. I agree, i always use a compound that is used for final polish in spray shops, and usually the finest i can get a decent gloss out of. Quote Link to comment Share on other sites More sharing options...
JS2004 Posted May 8, 2010 Author Share Posted May 8, 2010 Cheers guys hopefully I will get some good results ! Quote Link to comment Share on other sites More sharing options...
DamanC Posted May 9, 2010 Share Posted May 9, 2010 I agree, i always use a compound that is used for final polish in spray shops, and usually the finest i can get a decent gloss out of. That again. My paint is rock hard = Bonet = 6 hours! Quote Link to comment Share on other sites More sharing options...
