Mas Posted May 7, 2010 Share Posted May 7, 2010 After a simple jump start issue which got me spending on a 120A fuse and a ignitor, now that fitted both the car started once again but poorly! Anyway, I went to check the diagnostics code and then the car went mad!!! Now it doesnt start, the dash lights will go off as soon as I try to turn the ignition on, annoying clicking noise comes from the back of the dials as soon as I turn the ignition off! once its ON cant hear it anymore! while the clicking noise is on my DVD player flashes all the time! Boost controller was showing throttle from 0-6 and kept going up and down even though the car wasnt even started ! now the controller doesnt even turn itself ON! Alarm stopped working completely! the alarm flashing LED ligh keeps flashging same time as the annoying noise I mentioned! Ther so many other things wrong which I dont remember Anyone has any idea what the hell happened to the car suddenly? Thanks Quote Link to comment Share on other sites More sharing options...
gaz1 Posted May 7, 2010 Share Posted May 7, 2010 sounds like a dead battery Quote Link to comment Share on other sites More sharing options...
a98pmalcolm Posted May 7, 2010 Share Posted May 7, 2010 yer sounds like bat to me aswell, check all the fuses aswell Quote Link to comment Share on other sites More sharing options...
Mas Posted May 7, 2010 Author Share Posted May 7, 2010 Battery is 15 days old, brand new Really had enough of this, such small thing turns into a 2 month drag Quote Link to comment Share on other sites More sharing options...
Supranature Posted May 7, 2010 Share Posted May 7, 2010 (edited) Looks to me that your alarm immobiliser has taken a hit after your initial electrical mishap. No dash lights when the key is turned (on mine) means the immobiliser is on. Assuming you are mobilising the system (apparently), then this points to being the source of your current woe. Have you had a proper auto-spark check it over? Are you sure the new igniter pack is working? Edited May 7, 2010 by Supranature (see edit history) Quote Link to comment Share on other sites More sharing options...
Mas Posted May 11, 2010 Author Share Posted May 11, 2010 Hi folks, got the car started again and it seems like the new battery is very low and doesn't have enough charge to start up the car etc! When I jump start the car, starts ok but as soon as I remove the jump leads turns itself off in few seconds! Engine light keeps flashing none stop when I check the diagnostics! Red rectangular is ON all the time and the steerng wheel is like a rock heavy to move! any idea what else needs to be checked here as I want to get th car ready for Saturday to finally meet you after 2 years Cheers Mas Quote Link to comment Share on other sites More sharing options...
Cerikbok Posted May 11, 2010 Share Posted May 11, 2010 Could be you got a bad battery, my wifes MX-7 got a new battery and it was dead 3 weeks later, hopefully it is a simple fix for you Quote Link to comment Share on other sites More sharing options...
evinX Posted May 11, 2010 Share Posted May 11, 2010 Halfords calcium is the way to go! i had mine left for weeks disconnected, put it on the supra, and fired first time, well worth the £80 with 3 yrs garuntee. Quote Link to comment Share on other sites More sharing options...
wilson4347 Posted May 11, 2010 Share Posted May 11, 2010 Il second that^^^^ Quote Link to comment Share on other sites More sharing options...
wilson4347 Posted May 11, 2010 Share Posted May 11, 2010 Forgot to mention i have had similar problems and turned out to be a faulty toyota battery, the battery was only two months old! cant fault the halfords calcium!!!! Put it on and fired up straight away!! Quote Link to comment Share on other sites More sharing options...
snake Posted May 11, 2010 Share Posted May 11, 2010 is the battery being charged up by the alternator do a voltage check Quote Link to comment Share on other sites More sharing options...
absz Posted May 11, 2010 Share Posted May 11, 2010 your alternator is NOT charging if the engine cuts out once the jump leads are removed, do you have a battery light on dash with ignition on ? Quote Link to comment Share on other sites More sharing options...
Mas Posted May 11, 2010 Author Share Posted May 11, 2010 What a nightmare! Just got back after standing on hard shoulder trying to get a jump start and again as soon as some one helped an gone the car turned itself off! Think it's the alternator tbh but wh everything gone wrong all in the same bloody month! Left the car somewhere in an off road to see what I could possible do tommorrow but the problem is, can't get the car towed due to the after Market front bumper and it's too low to go on a recovery van!! Having enough the bloody car now, stupid little problems but very annoying now Quote Link to comment Share on other sites More sharing options...
