Supra 2JZ MR2 (FR2)
greeny
Wasnt sure which section to post this in??
Came across this,
From the good old US of A...
Engine Spec. aluminum connecting rods, CP Pistons, ARP L19 Head Studs, HKS Camshaft, Ferrea valves, springs and retainers, Precision Turbo Charger Engines, Moran 600lbs injectors (per inj.) Electromotive ECU, G force transmission, Mechanical fuel pum, Precision Turbo Water-Air-cooler, 33"x16" Tires, and more ... we use methanol fuel, the car have two years under construction, was started the last month. I hope go to the dyno at the end of May. We expect 1100-1350hp. and run 6.9-7.3 at the quarter mile. another pictures of the Car...
Guest damo1
look at the size of the blower how much air does that suck in? alot of cash spent there but i wudnt use a mr2!!!
Something with that short a wheelbase must be "interesting" at speed ! :)
Indeed!
Im sure on the first full power run he'l be a little nervous!
An MR2 with 600hp can put you sideways at the top end of the track on R888's :D
Nevermind with those size slicks and twice the power!
(although theres not much left of the original chassis and suspension setup)
