Running a Second Screen? (laptop Related)
Tricky-Ricky
I want to run some engine OBD-11 software on a screen in my new car, run from an old laptop, my question is can you get a converter to go from the laptop VGA or even S-video to an RCA video with sound as well if pos?
And also the screen is NTSC so i presume that could be a problem, so is the output dependant on what the laptop outputs? or can this also be coveted in the process?
Thanks guys but you misunderstand, my laptop has both VGA and S-video out, i just though i would include both as options, as i don't know which would be the easier to convert from.
I know both VGA and S-video have the separated video signals so they need some kind of converter in order to use a single video RCA?
But further to that once converted to the RCA, is the signal PAL or NTSC? and what can be done to convert to NTSC should it be PAL.
got ya. s-video to RCA would be easiest. plenty of cables available, have a play around with your video settings on the laptop you should be able to adjust the output video settings, from pal/ntsc and refresh rate, if you dont have these settings you may need to update your video driver.
You will need another cable for your audio though but again lots of cables available to slip from 3.5mm jack to rca's
Thanks mate, the graphics card is an inbuilt Nvidia GeForce 700M/nForce 610M and on going through the settings there doesn't seem to be an adjustment for TV standards, maybe it will require the connection to be made? there are some further settings but they still don't mention TV standards/outputs.
Will have to check my older laptop and see if thats any better, but i doubt it, is there any converters for this available? or is there a further solution?
