Steering Rack Gaitors
dandan
Hi guys,
Could anyone tell me the part numbers for 1996 TT steering rack gaitors?
Does anything else need replacing (or purchasing separate to these) while I do the gaitors and also, do they come with any grease for the innards?
Many thanks
Dan
p.s. I have come across 45535-24030 steering rack boot one and 45535-14070 steering rack boot two but I'm not certain they are for a 1996 TT.
There're retaining clips on each end of the gaitors.
As far as I remember the small clips can be used again, they're the spring type that you see on hoses that you squeeze together with pliers. I don't think the larger ones can be used again, I can't remember if I just used cable ties. (2 on each end to be safe) :)
