mixad Posted May 4, 2010 Share Posted May 4, 2010 9,5 rear offset 25 8,5 front offset 25 Can I run this setup without rolled fenders? And how do i know if they fit over UK-brakes? Link to comment Share on other sites More sharing options...
Nic Posted May 4, 2010 Share Posted May 4, 2010 I'm pretty sure those widths and offsets will rub without rolling the arches. It's impossible to say whether a wheel will clear the larger brake calipers based on just the width and offset. It varies from wheel to wheel, it depends on the design of the wheel, thickness of the spokes, dish of the wheel, width and offset, etc. Any decent trader should be able to advise what size and offset you will need. Link to comment Share on other sites More sharing options...
Brad88 Posted May 5, 2010 Share Posted May 5, 2010 Depends on your tyre sizing as well. I run 19x8.5+18 & 19x10.5+36 without rolled arches (going to roll the rears shortly though) as there is a little rubbing. 225 and 255 tyres on at the moment, a little narrower than my last wheels but anything wider and it will require much more rolling. Link to comment Share on other sites More sharing options...
Dnk Posted May 5, 2010 Share Posted May 5, 2010 Depends on your tyre sizing as well. I run 19x8.5+18 & 19x10.5+36 without rolled arches (going to roll the rears shortly though) as there is a little rubbing. 225 and 255 tyres on at the moment, a little narrower than my last wheels but anything wider and it will require much more rolling. You should really have a 265 or 275 wide tyre on a 10.5" wide wheel. Link to comment Share on other sites More sharing options...
