Rob_Mitchell Posted May 4, 2010 Share Posted May 4, 2010 hey guy i have a problem, i was driving home fro the show yesterday and all of a sudden i heard a noise and the car just ran like a pig and misfired constantly. the cat temperature light came on then so did the triangle warning light, i made it to the services to check levels etc then managed to get it down to our garage. i have a suspision its the cats breaking up restricting the flow but im not 100% please if anyone has a idea let me know. thanks rob Quote Link to comment Share on other sites More sharing options...
Nic Posted May 4, 2010 Share Posted May 4, 2010 Do you have a boost gauge fitted? Are you seeing positive boost? Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted May 4, 2010 Share Posted May 4, 2010 Do you have a boost gauge fitted? Are you seeing positive boost? He's never seen positive boost, it's an NA ----- Is it firing on all cylinders mate, or is it clearly missing.? If the triangle is on, something is definitely amiss, check for fault codes. Quote Link to comment Share on other sites More sharing options...
Nic Posted May 4, 2010 Share Posted May 4, 2010 He's never seen positive boost, it's an NA Ah! That'll be the problem then Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted May 4, 2010 Author Share Posted May 4, 2010 yeah definately misfiring mate running well rough, its definately got hot as the back box has gone blue. the cat temperature light is making me think its the cats broken up but cant hear any rattles. ill have to get it over the pitt when i get 5 mins Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted May 4, 2010 Author Share Posted May 4, 2010 anyone else have a clue?????? Quote Link to comment Share on other sites More sharing options...
ManwithSupra Posted May 4, 2010 Share Posted May 4, 2010 What sort of noise was it? (Bang, knock etc) Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted May 4, 2010 Author Share Posted May 4, 2010 just went funny sort of a knock noise i guess then lose of power due to misfire, had to poodle along till i got to the services Quote Link to comment Share on other sites More sharing options...
ManwithSupra Posted May 4, 2010 Share Posted May 4, 2010 Have you pulled the error codes as yet? That is what i would do first at least then it could show you where to start looking, I would then pull the plugs to check them for damage (missing ceramic etc), then do a compression test to be safe. Get all that out of the way first then go from there. Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted May 4, 2010 Share Posted May 4, 2010 You might be right about the CAT mate, it would certainly increase temps, but I've never seen one let go all of a sudden, they break up over time AFAIK. Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted May 4, 2010 Author Share Posted May 4, 2010 Have you pulled the error codes as yet? That is what i would do first at least then it could show you where to start looking, I would then pull the plugs to check them for damage (missing ceramic etc), then do a compression test to be safe. Get all that out of the way first then go from there. not sure how to do the trouble codes ill have to read up on it, yeah them checks are what im going to do soon just as everything is going well, this happens its a pain lol Quote Link to comment Share on other sites More sharing options...
Abz Posted May 4, 2010 Share Posted May 4, 2010 Here you go mate on how to check the error codes: http://www.mkivsupra.net/vbb/showthread.php?t=35920&highlight=error+codes Hope you get it sorted soon without too much trouble! What was you doing when it happened? Was you picking up speed quickly? Going round a bend? Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted May 4, 2010 Author Share Posted May 4, 2010 Here you go mate on how to check the error codes: http://www.mkivsupra.net/vbb/showthread.php?t=35920&highlight=error+codes Hope you get it sorted soon without too much trouble! thanks abz ill try and work it out. i hope its not too drastic but will try and find out soon- that bloody bluewater meet is a jinx i will make it to one one day Quote Link to comment Share on other sites More sharing options...
Abz Posted May 4, 2010 Share Posted May 4, 2010 thanks abz ill try and work it out. i hope its not too drastic but will try and find out soon- that bloody bluewater meet is a jinx i will make it to one one day You have no excuses mate, it still runs Quote Link to comment Share on other sites More sharing options...
Scooter Posted May 4, 2010 Share Posted May 4, 2010 Surely with the cat warning light and the symptoms (sluggish and misfire) of this being blocked mean it must be that?............I'd whip it off and start the car without it and see if it starts, idles and revs ok.........I have a NA 2nd cat if it is that and you want one quickly.... Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted May 4, 2010 Author Share Posted May 4, 2010 Surely with the cat warning light and the symptoms (sluggish and misfire) of this being blocked mean it must be that?............I'd whip it off and start the car without it and see if it starts, idles and revs ok.........I have a NA 2nd cat if it is that and you want one quickly.... thanks mate fingers crossed thats what its going to be and ill be a happy boy. yeah expect a pm later mate about the cat, thanks alot Quote Link to comment Share on other sites More sharing options...
themodifiedkid Posted May 4, 2010 Share Posted May 4, 2010 Just clutching at straws here but have you checked ht leads, distributor cap/rotor arm, (all that polishing you did yesterday you've probably polished through the ht leads and moisture has got in LOL) Mind you faulty ht leads etc wouldn't account for the high temps Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted May 4, 2010 Author Share Posted May 4, 2010 right guys i think i have solved the problem, i stripped it all down and i noticed the back 2 plugs gallerys were full of water due to the rear heater hose having a tiny slit in it. this is obviously causing the misfire, just need to order that hose tomorrow. thanks everyone for the pm's and replys yet again everyone has been awesome. Quote Link to comment Share on other sites More sharing options...
Abz Posted May 4, 2010 Share Posted May 4, 2010 right guys i think i have solved the problem, i stripped it all down and i noticed the back 2 plugs gallerys were full of water due to the rear heater hose having a tiny slit in it. this is obviously causing the misfire, just need to order that hose tomorrow. thanks everyone for the pm's and replys yet again everyone has been awesome. Glad you found the problem Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted May 4, 2010 Author Share Posted May 4, 2010 Glad you found the problem well i hope thats the problem lol Quote Link to comment Share on other sites More sharing options...
Abz Posted May 4, 2010 Share Posted May 4, 2010 well i hope thats the problem lol I am sure you will find out in the morning Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted May 4, 2010 Author Share Posted May 4, 2010 ill keep everyone posted, so fingers crossed. Quote Link to comment Share on other sites More sharing options...
straightsix Posted January 14, 2011 Share Posted January 14, 2011 What was the cause? Mine's doing exactly the same. I'm going to look at it in the morning Quote Link to comment Share on other sites More sharing options...
jagman Posted January 14, 2011 Share Posted January 14, 2011 Cat light can come on with no alternator output or low voltage Quote Link to comment Share on other sites More sharing options...
