Matt H Posted May 2, 2010 Share Posted May 2, 2010 Drivers, windscreen side bolt I think I've threaded it as it won't go back on properly. Has anybody ever replaced one before? What does it entail and is there anything you need to know before doing so? Also, I take it these are available as a part from Toyota? Ta Matt Quote Link to comment Share on other sites More sharing options...
hodge Posted May 2, 2010 Share Posted May 2, 2010 It's pretty straight forwards Matt if I recall. Remove the roof trim and unbolt the bolt and replace. If that makes sense. Quote Link to comment Share on other sites More sharing options...
Matt H Posted May 2, 2010 Author Share Posted May 2, 2010 It's pretty straight forwards Matt if I recall. Remove the roof trim and unbolt the bolt and replace. If that makes sense. Aye, course it does, nice and straight forward - Just how I like it Hopefully the roof thread isn't damaged too. I'll be phoning my local Toyota on Tues then. Ta Quote Link to comment Share on other sites More sharing options...
Matt H Posted May 9, 2010 Author Share Posted May 9, 2010 Well I've taken the roof back as far as I can. The bolt I need to replace is underneath the skin of the roof and I'm not sure if it can be gotten to? Any ideas? (the bolt is located in the area of white) Quote Link to comment Share on other sites More sharing options...
Homer Posted May 9, 2010 Share Posted May 9, 2010 I don't have access to EPC on this laptop, but looks like there is a plate sandwiched in there and weld closed. Potentially not easy to replace. No suggestions for now Matt, but someone with EPC should be able to see how that area is built. Quote Link to comment Share on other sites More sharing options...
Matt H Posted May 9, 2010 Author Share Posted May 9, 2010 I don't have access to EPC on this laptop, but looks like there is a plate sandwiched in there and weld closed. Potentially not easy to replace. No suggestions for now Matt, but someone with EPC should be able to see how that area is built. Cheers Homer. Yes I think you're right; there's some form of plate that the bolt sits in and like you say, no apparent way in! What is EPC btw? Quote Link to comment Share on other sites More sharing options...
Matt H Posted May 9, 2010 Author Share Posted May 9, 2010 Electronic Parts Catalogue. Wow, didn't know people had access to that! Is this it? http://www.yankeetoys.org/docs.htm Quote Link to comment Share on other sites More sharing options...
Homer Posted May 9, 2010 Share Posted May 9, 2010 EPC has been publically available for as long as I've been here Never seen that link before, it looks a little small file size, but might do the trick. The one I use is Nic's full version, but is over 3 GB. My main PC is bust so can't access it now. I'm sure someone with the full supra one will be able to do a quick check on the parts tomorrow. Quote Link to comment Share on other sites More sharing options...
nevins Posted May 9, 2010 Share Posted May 9, 2010 So the bolt was cross threaded into the thread in the roof. Have you tried tapping it, as you may be able to save the thread. This would be the first step I would take before trying to gain access to the captive nut. Quote Link to comment Share on other sites More sharing options...
hodge Posted May 10, 2010 Share Posted May 10, 2010 I recon tapping it is your only option. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted May 10, 2010 Share Posted May 10, 2010 Id have said re-tap it, just enough to clean the thread up and not cut a new one. Quote Link to comment Share on other sites More sharing options...
Matt H Posted May 10, 2010 Author Share Posted May 10, 2010 EPC has been publically available for as long as I've been here Never seen that link before, it looks a little small file size, but might do the trick. The one I use is Nic's full version, but is over 3 GB. My main PC is bust so can't access it now. I'm sure someone with the full supra one will be able to do a quick check on the parts tomorrow. Hopefully someone wil pop along soon with that. Even though the following idea sounds good, I'd still love to know If I can get to it as it stands for future rref. So the bolt was cross threaded into the thread in the roof. Have you tried tapping it, as you may be able to save the thread. This would be the first step I would take before trying to gain access to the captive nut. I recon tapping it is your only option. Id have said re-tap it, just enough to clean the thread up and not cut a new one. I never thought of that. Brilliant shout. I reckon my best bet is to take it to an engineering shop to have it done proffesionally. Cheers Chaps, Quote Link to comment Share on other sites More sharing options...
Digsy Posted May 10, 2010 Share Posted May 10, 2010 I never thought of that. Brilliant shout. I reckon my best bet is to take it to an engineering shop to have it done proffesionally. Cheers Chaps, Before you go to that bother I'd buy a tap and try to run it down myself. If you do wind up having to go to a machine shop then get them to insert a helicoil or a-n-other type of thread repair insert. Quote Link to comment Share on other sites More sharing options...
Matt H Posted May 10, 2010 Author Share Posted May 10, 2010 Before you go to that bother I'd buy a tap and try to run it down myself. If you do wind up having to go to a machine shop then get them to insert a helicoil or a-n-other type of thread repair insert. If that bolt won't come out, I should probably get it done right, otherwise I'm risking the entire roof being made redundant if I mess it up Quote Link to comment Share on other sites More sharing options...
AndrewOW Posted May 10, 2010 Share Posted May 10, 2010 If that bolt won't come out, I should probably get it done right, otherwise I'm risking the entire roof being made redundant if I mess it up There's a carbon roof for sale, somewhere on here, just in case. Quote Link to comment Share on other sites More sharing options...
AndrewOW Posted May 10, 2010 Share Posted May 10, 2010 This one: http://www.mkivsupra.net/vbb/showthread.php?t=215165&highlight=roof I don't think it's sold yet, but you could have that and get it painted if need be. Quote Link to comment Share on other sites More sharing options...
Matt H Posted May 10, 2010 Author Share Posted May 10, 2010 Carbon's not my bag, but having it sprayed would be awesome. Still, it's £600 I'd prefer to spend elsewhere. Quote Link to comment Share on other sites More sharing options...
