External wastegate, what size
hodge
Maybe some good info here??
Across the broad array of message boards we see a large amount of misinformation. Sadly this bad info can lead somebody into purchasing the wrong part. One common bit of internet hearsay is "The bigger the turbo the bigger the wastegate!" So is this fact or myth? This write-up may influence your next wastegate purchase.
Generally speaking running lower boost levels, requires a larger wastegate. The theory is more exhaust gas needs to diverted (wasted) away from the turbine wheel during low boost conditions. While running high boost levels, a majority of the exhaust needs to be directed into the turbine wheel to spool the turbocharger.
Example A: A GT42R turbocharger on a 1.6L engine would require a smaller wastegate because a majority of the exhaust flow from the engine would be required to spool the turbine wheel.
Example B: A GT25R on a 3.0L engine attempting to run low boost pressure would require a large wastegate because a majority of the exhaust flow needs to be diverted away from the turbine wheel to keep the turbo from boost creep or over boosting.
check;
http://www.fftec.com/WastegateSizing.html
