VVti inlet/plenum
ray007
Hi all, im thinking of getting an aftermarket inlet/plenum for my VVti TT.
i know you cant use the standard ones but i found one for a 1jz vvti on ebay, would this fit the 2jz vvti?
http://cgi.ebay.com/ebaymotors/toyota-supra-1jz-gte-vvti-1jzgte-vvti-intake-manifold-_W0QQcmdZViewItemQQhashZitem414f10b9efQQitemZ280499370479QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories#ht_500wt_1182
if not does anyone know where to get one for the 2jz vvti?
First question is, obviously, why? Stock intake manifold is plenty good for power up to 600-700 hp. How much power do you plan to make if the standard one isn't adequate?
Secondly, if you're just after looks then you'll probably end up with something shiny that doesn't perform better than the standard one unless you spend some coin for a VW, Hypertune, Veilside, Greddy or *decent* custom jobbie.
Thirdly, by replacing the intake manifold you will lose drive-by-wire, traction control, and some stock sensors for IACV etc. Which will be a pain for you, if this car isn't going to make some decent power to compensate.
Cliffs = don't replace it, unless you have to because it's a restriction to your power levels.
Hope this helps.
