IT bods: question about wi-fi.
RedM
Thinking of getting a wi-fi modem/router at last. My laptop is about two years old and has this gubbins inside:
Intel® Wireless WiFi Link 4965AGN (dual-band quad-
mode 802.11a/b/g/Draft-N) Wi-Fi CERTIFIED® network
connection, supporting Acer SignalUpTM with InviLinkTM
NplifyTM wireless technology (for selected models), or
Intel® PRO/Wireless 3945ABG (dual-band tri-mode
802.11a/b/g) network connection Wi-Fi CERTIFIED®
solution, supporting Acer SignalUpTM wireless
Does that limit which modem/routers I can buy? What should I be looking for before I hand over my hard earned.
Oh, I also need it to be able to work with my new (when it chuffin' arrives) mobile. That has:
Wi-Fi®: IEEE 802.11 b/g
Can someone point me in the direction of a decent router/modem that will work with both, please? I haven't a clue what I'm looking at!:blink:
Thanks.
You can get pretty much any router you wish with those specs. Wireless N is the fastest available at a reasonable price but I would advise against it to be honest. I got a Wireless-N router and the range is crap. I have gone through 3 different ones all boasting massive range but they have been nothing compared to the Wireless G router I had. As soon as a wall is in the way, it is hopeless.
I have been seriously considering going back to a WRT54G-s.
With modern modems you have the choice of an all in one, or a DSL router. If the modem you have plugs into the ethernet port of your PC then you can get whatever one you wish. If it plugs into USB then I think you are restricted to ADSL modem/Routers.
I always recommend Linksys, other than their Wireless-N routers they have been flawless for me. WRT54G-s is the best on the market as far as budget G routers go.
Out of Belkin and Netgear which is the best at dealing with walls that might hinder the signal?
Linksys ;)
Out of Belkin and Netgear, I'd say Netgear.
I'd probably go for a Linksys too if I were going for a new router, however.
Looking at that Linksys WRT54gs I'm reading that there may be some issues as to whether my ISP will support it. Something to do with PPPOA and PPPOE.
I think I need PPPOA as I can't connect with my modem set to PPPOE. Any ideas?
Also, is seems to be an old unit that is no longer available from Linksys. So, any recommendations for new models?
Wireless router choices.. Whatever you go for make sure it has an external antena. Makes a huge difference and even allows for certain level upgradebility.
any of this lot are pretty good, some have been around for a while now Linksys' WRT54G/GL/GS. The advantage of these is that you can change the firmware to Tomato, which will give you much greater flexibitly and loads more features.
Once you have got all that sorted, hopefully all your devices will be 802.11 G complient, in which case make sure the router is set to just this frequency group. Cutting out all the listening and broadcasting on the B will help improve performance.
(most devices support the G system by now, but there are still the odd devices around that only support B like the Nintendo wii!. Trial and error is probably quickest way to tell.)
Yeah you're right. You can set the modem up as a bridge etc but it can be a bit of a pain and not all modems would be compatible.
http://cgi.ebay.co.uk/Linksys-WAG54GS-Wireless-Router-Speed-Booster-/200467752380?cmd=ViewItem&pt=UK_Computing_Networking_SM&hash=item2eaccf25bc
That would be more suited to what you are after. The router has a built in modem so you can just set it up with your settings and use the one device. This router is basically the same as the WRT model.
They are all old routers bud. The reason I am recommending them over the newer ones is that they are all wireless-N routers now. As I say, I find the range terrible. With the WRT54G I get a signal outside my house.
Interesting thread. I changed over to Virgin Broadband a week or so ago and the output range of the D-link router we now have is awful. I can't get a decent internet signal upstairs very well and unless you are about 10 feet from it, it is never at full strength.
We used to have a Netgear router that had great range but we had to keep resetting it every couple of hours......:rolleyes:
I wouldn't mind but I changed my broadband provider so I could get a free router and have ended up worse off in some ways. On the other hand, internet gaming is much better through Virgin but the Xbox is hard wired to the router.
H.
H.
Hard wired is always the better option, kinda spoils the whole laptop idea though.
I dont know much about the router they give out with virgin. does it have socket on the back that you can attach an antena too?
Next question:
We have tried wi-fi in the past and had very poor signal. I think it is because of the layout of our flat plus we live above a shop with lots of electrical 'interference'.
Might a dual-band modem-router work better in this case?
Dont forget any of you that if you are using one of those wireless TV in any room type systems to get Sky or Virgin to your bedroom it will have a serious affect on the wifi performance.
I had to fix somebodys system the other day where the router was upstairs, working fine, worked all around the house including the kitchen, but as soon as I walked in to the lounge it dropped it completely. Shifted the wifi router channels down to 2 and still had the problem, so turned it up to 13 and it was fine.
So worth bearing in mind.
Just as Branners has said, once you have your router start playing around with your settings until you get the best results. There are a few guides online, but changing the channels through the odd numbers is the norm, until you find the best one for you.
As i said before, if it comes with external antenna(s) you will normally get a good signal throughout the house. If your still having trouble, swap the antenna for one with greater gain(or have a go a making one yourself http://www.videojug.com/film/how-to-do-a-wifi-antenna-hack).
  • 2 weeks later...
