Guest sinie Posted May 1, 2010 Share Posted May 1, 2010 you mean "it was meant to be a brand new pump" Quote Link to comment Share on other sites More sharing options...
L33 Posted May 1, 2010 Author Share Posted May 1, 2010 bit of a lurker on here, use the forum mainly for information when playing with a mates supra years back, lee as said on the phone mate, ill boot round tomorrow, strip the covers off and take a look with you, will give you a call tomorrow when heading over, ill bring some tools, and well crack on, chin up mate cheers mike i hope the weather gets better and ian i didnt take any more pics as there is no oil any where else under the whole car?! Quote Link to comment Share on other sites More sharing options...
Guest sinie Posted May 1, 2010 Share Posted May 1, 2010 were waterproof for a reason, rain dont bother me, i got a brolly lol Quote Link to comment Share on other sites More sharing options...
L33 Posted May 1, 2010 Author Share Posted May 1, 2010 you mean "it was meant to be a brand new pump" lol u get the idea! looking at it tho it looks clean so i hope thats the one they fitted! Quote Link to comment Share on other sites More sharing options...
dude Posted May 1, 2010 Share Posted May 1, 2010 The position of the oil is making me think maybe the leak is from the oil pressure sender? They have been known to leak and then suddenly fail, and the oil doesn't stay in for long after that. It doesn't explain the bang, unless it was the sender unit parting company with the car and ricocheting off the road back into the underside. It might also explain the warning light if the sensor isn't there any more. I'd kinda expect more oil around the place than that though. Need more pics of the underside, further back. Another look and I also think it could be the front main seal. The oil spray is quite directional, possibly from coming off the back of the crank pulley at high revs. Can you check the back of the crank pulley for oil? Thats what I thought first Ian, maybe the sender fell out!!!! Or the middle has shot out but if that was so I would expect more oil Quote Link to comment Share on other sites More sharing options...
dude Posted May 1, 2010 Share Posted May 1, 2010 Lee, Times like these bud are a test and everyone goes through them mate. Last year i went through a ruff patch and my 5 1/2 year reletionship GF left me also but Trust Me everything happens for a reason IMO and you learn from it all. Things will get better!! Now lets find out whats happened. Firth thing i would do is give StuartW a shout on here. He is local to you and knows alot about supra's, im sure he wont mind popping over and looking over it. Now when the engine turns over does it sound the same as usual ie no bangs and knocks etc. Next take the cam cover off and see if the cam belt is still in one piece. Does the Dash red oil pressure light go off when cranking? Does the RPM counter flicker slighty at all when cranking? For some reason i have a feeling the timing star might have fell of its pulley and it might of damage the oil pump if the oil pressure light is not going out. Ryan My 2nd thought was the timing star as ryan says and maybe somehow that screwed the oil seal, do you not have a suplementry oil pres guage???? Quote Link to comment Share on other sites More sharing options...
Miguel Posted May 1, 2010 Share Posted May 1, 2010 Thats what I thought first Ian, maybe the sender fell out!!!! Or the middle has shot out but if that was so I would expect more oil Beat me to it!!! My first thoughts were FMS, sender unit or the oil-way grub screw hidden behind the AC pump, which is easy to forget on rebuilds, but the lack of oil makes me question that also. Quote Link to comment Share on other sites More sharing options...
dude Posted May 1, 2010 Share Posted May 1, 2010 If we knew for sure if it actually HAS oil presure that would make it easier to diagnose, if the sender has self destructed then it won't show oil pressure even if it has some!!!!! Quote Link to comment Share on other sites More sharing options...
L33 Posted May 1, 2010 Author Share Posted May 1, 2010 i have no idea! suplementry oil pres guage? i have a oil pressure gauge reading 0 now Quote Link to comment Share on other sites More sharing options...
L33 Posted May 1, 2010 Author Share Posted May 1, 2010 the red oil light thing is on on the right hand side and car wont start Quote Link to comment Share on other sites More sharing options...
dude Posted May 1, 2010 Share Posted May 1, 2010 i have no idea! suplementry oil pres guage? i have a oil pressure gauge reading 0 now Where is the sender for the oil guage Lee, you have a guage fitted as it reads 0 !!!!!! do you know where your 'tuner' fitted the sender for the guage, the easiest way to fit one is in a sandwich plate between the filter and its housing, do you still have the factory oil light, not level the pressure one, if so does that go out or stay on, does the engine knock or sound starnge at all. Quote Link to comment Share on other sites More sharing options...
L33 Posted May 1, 2010 Author Share Posted May 1, 2010 it used to read 2, but now its 0 and wont start! sounds like it wants to but wont actually start! no idea where its fitted, i will have to have a look tomo for the sandwich plate the only light thats on is a red oil can on the right hand side of dash which according to manual is oil pressure? Quote Link to comment Share on other sites More sharing options...
dude Posted May 1, 2010 Share Posted May 1, 2010 Sounds to me like the timing star has come off the back of the timing pulley behind the crank pulley, as long as it hasnt smashed the crank sensor it is an easy fix. Quote Link to comment Share on other sites More sharing options...
dude Posted May 1, 2010 Share Posted May 1, 2010 it used to read 2, but now its 0 and wont start! sounds like it wants to but wont actually start! no idea where its fitted, i will have to have a look tomo for the sandwich plate the only light thats on is a red oil can on the right hand side of dash which according to manual is oil pressure? Used to read 2, I take it that is bar and you are talking tickover!!! if it was reading 2 at high revs then there is a more serious problem. Quote Link to comment Share on other sites More sharing options...
Guest sinie Posted May 1, 2010 Share Posted May 1, 2010 ill have a look tomorrow, will drop covers and see what's what, and lee will post up whatever results we find, its a shame, as the car was an absolute monster, 160 leptons in very little space ;-) but the EGT gauge reading 1000degrees seemed a little high?? Quote Link to comment Share on other sites More sharing options...
Miguel Posted May 1, 2010 Share Posted May 1, 2010 EGT gauge reading 1000degrees seemed a little high?? Celsius? I hope not! Quote Link to comment Share on other sites More sharing options...
Guest sinie Posted May 1, 2010 Share Posted May 1, 2010 his defi gauge reads up to 11, and we tapped ten on a quick run, will check with hi if its in celsius or Fahrenheit Quote Link to comment Share on other sites More sharing options...
Miguel Posted May 1, 2010 Share Posted May 1, 2010 Why do I get the feeling there is more to this story. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted May 1, 2010 Share Posted May 1, 2010 Thats really bad news mate, i do hope is a easy fix after all your troubles. In the last two pics i think i can see an area that looks like its broken alloy, but that would be the oil pump and if it where serious there would be much more oil, i am inclined to go along with the CPS star coming off theory, good luck anyway. Quote Link to comment Share on other sites More sharing options...
Ian C Posted May 1, 2010 Share Posted May 1, 2010 Can you check for error codes Lee? A code 12 or 13 would be the crank position sensor. Thing is, despite there not being much oil, why would the low oil light be on? If it was low oil or oil pressure it'd still start (although that would be a bad thing with no oil of course). If it's the CPS setup then why the low oil light warning..? Hmmm. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted May 1, 2010 Share Posted May 1, 2010 Bad luck Lee, a nightmare on many levels On the 1st and 4th pics above the bottom air con compressor mount it looks like something has snapped off the casing, is that normal? My first though is timing as well. Hope you get it sorted and dont sell but I can totally understand why you woukd want to. Quote Link to comment Share on other sites More sharing options...
Ian C Posted May 1, 2010 Share Posted May 1, 2010 his defi gauge reads up to 11, and we tapped ten on a quick run, will check with hi if its in celsius or Fahrenheit That's going to be degrees C 1000 is way too high for a single turbo setup, you shouldn't see past about 850degC. Quote Link to comment Share on other sites More sharing options...
jon5698 Posted May 1, 2010 Share Posted May 1, 2010 Gutted to hear this mate, you have had so many problems with this car in the picture where i have circled does it look like something has snapped off? Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted May 1, 2010 Share Posted May 1, 2010 Yeah what I said lol. Quote Link to comment Share on other sites More sharing options...
jon5698 Posted May 1, 2010 Share Posted May 1, 2010 So you did lol, didn't see it. Quote Link to comment Share on other sites More sharing options...
