RedT18 Posted April 29, 2010 Share Posted April 29, 2010 Hi, my right hand warning lights dont work since a few weeks. I can remember that ik worked pretty well before. I heard that this might be a common problem on the car. Can aynone tell me how to repair? thank you in advance! regards, Bartosch Quote Link to comment Share on other sites More sharing options...
heckler Posted April 29, 2010 Share Posted April 29, 2010 Hi, my right hand warning lights dont work since a few weeks. I can remember that ik worked pretty well before. I heard that this might be a common problem on the car. Can aynone tell me how to repair? thank you in advance! regards, Bartosch the PCB will require re-soldering - 5 min job Quote Link to comment Share on other sites More sharing options...
Kirk Posted April 29, 2010 Share Posted April 29, 2010 Same issue with mine. Do i need to just add some fresh solder or melt the old off and apply new? Quote Link to comment Share on other sites More sharing options...
Abz Posted April 29, 2010 Share Posted April 29, 2010 the PCB will require re-soldering - 5 min job Heckler any chance you could elborate on this? I also have the same issue & have in the past just tied the wires more closely to the loom but then it still seems to sometimes loose connection. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
Brad88 Posted April 30, 2010 Share Posted April 30, 2010 the PCB will require re-soldering - 5 min job Same issue with mine. Do i need to just add some fresh solder or melt the old off and apply new? I've done a few of these, typically theres plenty of soldier there to simply melt it and let it reseal, it literelly is a 5 minute job. Quote Link to comment Share on other sites More sharing options...
heckler Posted April 30, 2010 Share Posted April 30, 2010 Heckler any chance you could elborate on this? I also have the same issue & have in the past just tied the wires more closely to the loom but then it still seems to sometimes loose connection. Thanks in advance. a quick dab of the soldering iron of the connections on the back of the white plug should cure it. Quote Link to comment Share on other sites More sharing options...
Thorin Posted April 30, 2010 Share Posted April 30, 2010 Give it a smack, you'll probably find they'll start working again (although probably temporarily). Quote Link to comment Share on other sites More sharing options...
Abz Posted April 30, 2010 Share Posted April 30, 2010 a quick dab of the soldering iron of the connections on the back of the white plug should cure it. Thanks Heckler Give it a smack, you'll probably find they'll start working again (although probably temporarily). I've tried this in traffic, you should have seen the reaction's I got from people in the lane next to me Quote Link to comment Share on other sites More sharing options...
Jay_vr6 Posted April 30, 2010 Share Posted April 30, 2010 I did mine 2 years ago when I got the supra and only yesterday did them again as they stopped working again, added fresh solder this time to make sure easy job to do at home Quote Link to comment Share on other sites More sharing options...
