Lude Posted April 29, 2010 Share Posted April 29, 2010 just wondering, do you have reverse with them? do they have clutches aswel? i can imagine they cost as much as a car as the getrag is quite a pricey number Quote Link to comment Share on other sites More sharing options...
jevansio Posted April 29, 2010 Share Posted April 29, 2010 (edited) Yes they have reverse, they have a clutch (although not operated by the driver in the usual fashion - operated automatically by the SMG system everytime it wants to change gear) EDIT just realised you prolly didn't mean the sequential manual gearbox like the BMW SMG system? Edited April 29, 2010 by jevansio (see edit history) Quote Link to comment Share on other sites More sharing options...
Lude Posted April 29, 2010 Author Share Posted April 29, 2010 no dont mean flappy pedal on the steering wheel ones, mean the boxes where you just pull the gearstick forward & back to change gear Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted April 29, 2010 Share Posted April 29, 2010 dtm style boxes. id love one of those Quote Link to comment Share on other sites More sharing options...
Stephen G Posted April 29, 2010 Share Posted April 29, 2010 have seen mk2 ecorts rally cars with sequential race boxes and all had reverse just had a small lever on the shifter to pull or lift when you had downshifted to first and stopped to then allow you to engage reverse Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 30, 2010 Share Posted April 30, 2010 Yes, most have a reverse as both rally and circuit race cars, for they are intended, have to have a reverse, although most cite reverse as a manoeuvring gear only, to be used gently. I fitted a Swedish Tractive sequential box to my RWD Skyline and it works superbly. Any of the proper race sequentials are going to be costly, but they hold a good resale value and if you use the car on track they are worth lap time. I wrote a write up on adapting one to fit an RB26 engine, doing the same on a 2JZ-GTE would follow very similar lines. I may be doing one for a customer this summer, using the bellhousing from a manual Soarer / MKIII 1JZ Supra. Funnily enough I am just finished machining and fitting an adaptor to fit a slightly bigger bore AP Racing clutch master cylinder on my car, as I wasn't 100% happy about pedal travel to release the triple plate clutch. It's fine now. Write up is at: http://www.mkivsupra.net/vbb/showthread.php?t=180791&highlight=tractive Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted April 30, 2010 Share Posted April 30, 2010 On small kit cars and the like with bike engines and boxes they have an electric reverse gear. Chris, I know its a moot point on racing cars but how much extra stress do sequential gear changes put on the rest of the transmission? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 30, 2010 Share Posted April 30, 2010 Very little, if any, why should they? The drive train knows and feels nothing about the gear selection method. Shock loads are governed by clutch slip, presence or lack of damped clutch plate hubs, solid or rubber engine and gearbox mountings, and diff mountings, and compliance or lack of in the prop shaft joints / couplings. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted April 30, 2010 Share Posted April 30, 2010 I meant the shock loadings mate, thanks for the reply Quote Link to comment Share on other sites More sharing options...
Nic Posted April 30, 2010 Share Posted April 30, 2010 Ikeya Formula do sequential shifter kits for a lot of different Japanese car models, unfortunately not the Supra. How difficult would it be to adapt say an R33 kit for the Supra Chris? http://www.ikeya-f.co.jp/en/product_notice/sequen_shifter.html Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 30, 2010 Share Posted April 30, 2010 I have yet to see an H pattern to sequential shifter kit that works. I had a Skyline in with the Ikeya thing on it, and it was basically a joke. It jammed, jumped and was generally a POS to be frank. Quote Link to comment Share on other sites More sharing options...
