what gearbox is fitted on this.
little num
Mark III
Also called Toyota Supra Mark III
Production 1986.5–1992 (1993 in Japan)
Platform MA7x
GA7x
JZA7x
Engine(s) 1,988 cc (1.988 L; 121.3 cu in) 1G-GTE I6
2,491 cc (2.491 L; 152.0 cu in) 1JZ-GTE I6
2,954 cc (2.954 L; 180.3 cu in) 7M-GE I6
2,954 cc (2.954 L; 180.3 cu in) 7M-GTE I6
Transmission(s) 5-speed W58 manual
5-speed R154 manual
4-Speed A340E automatic
Wheelbase 2,596 mm (102.2 in)
Length 4,620 mm (181.9 in)
Width 1,745 mm (68.7 in)
Height 1,310 mm (51.6 in) (1986.5-88)
1,301 mm (51.2 in) (1989-92)
Curb weight 1,537 kg (3,389 lb) (manual)
1,595 kg (3,516 lb) (automatic)
Anybody know what gearbox is fitted to the 7M-GTE on a H reg 1990? It's a Mk3 turbo Supra.
Would think R154 but then requires a shifter extension for ours, cost? Although some late Mk3 had the W58 like Swampy's.
Mk3 7M-GTE - R154
Mk3 1JZ-GTE - R154
Mk3 7M-GE - W58
Mk3 1G-GTE - W58
