Whats the best ?
Andrew Dunk Shaw
Having read lots of info on the various induction kits, i thought i'd ask what you guys think.
Im going to change from the hks unit, as i cant find a differant filter that will fit the hks pipewrk. Im looking for advice on which way to go.
Think the main thing has got to be that the filter is up to the job.
I dont want to waste another chunk of dosh so whats your thoughts boys.
Yes im begining to think the same thing.
So is there a second best option, ive virtually got my own airbox
designed now which will use the stock intake which sits on top of the radiator and also from underneath the headlamp using some donkey dik tubing and airducts that will sit behind the cut out in the stock front bumper where the drivers side indicator is.
Forgive me if I'm being a bit silly, but why would you want the second best option, when you already have the best one on there?
Its like replacing your Blitz exhaust with a stock one! why take a step back?
:confused:
£183 + vat for o/e Toyota airbox inc filter
So not too bad i suppose :conf:
And the filter itself from Toyota is about £30. (or maybe a bit more)
(It comes in it's own plastic grid holder thingy.).
you can't get just the paper filter, you need to buy the whole £30 thingy and then it basically just slots into the filter housing.
:confused:
Im only thinking of changing the hks induction kit due to a few comments on here and else where that the filters are not very good.
I can solve the under bonnet temps with my own custom airbox but im looking for an induction kit with a filter that does its job.
If there isnt an induction kit that comes with a good filter then i will go back to the stock airbox.
Andrew, as you know I have been looking into this as well, and from what I have gathered Apexi are the best followed by Blitz, K&N, and then HKS, these were bassed on filteration results.
Check these out that were passed on to me:
http://www.ftooc.org/contents/pages/project/filter.htm
http://www.mkiv.com/techarticles/filters_test/1/index.html
http://www.mkiv.com/techarticles/filters_test/2/index.html
:thumbs:
:thumbs:
Nice one Ashley.
Looks like the Apexi is the best aftermarket filter then,
and the HKS the worst.
You got your ride height problem sorted yet ?
