Autobox Problem, wont change up, revs stick
Harllequin
Hi there guys.
After much reading of the posts I could find with the search function I'm no further forward with what to do next.
Car: -
1993 GZ BPU+
Symptom
When going hard the car will not change up its gears, it goes to the red line and sticks there. It does this in all gears not just 3rd to 4th. If I back off to nothing then re apply the throttle it will change up its gears.
When I dive normal every day it changes up no problems at all.
When in manual mode the same symptoms are there just as they would be if it was in auto mode.
The car has also started to stick at random revs, some times it sticks at 4k RPM others at 3k RPM or goes to the red line and sticks there or any combination there off.
Here is the good part, this does not all happen at once, they are all faults the car does, but when it does them is completely random. Most of the time it runs great.
Checks so far: -
Oil level fine having checked it hot and gone through all the gears etc.
No fault code being displayed at all.
Vacume hoses that I can find all look in good order.
The oil does not smell burned and has a nice golden colour to it.
Well guys thats the story so far.
I'm not sure what to do next.
I had thought of changing the gearbox oil, not a full change or a flush, just dropping the old from the drain plug and doing a refill.
Cuting the wires to cure fault code 42 to see if that helps, even though its not showing any fault codes. yep I'm at the grasping at any idea time :)
Thanks in advance guys.
Darren
