Any vauxhall specialist HERE ?
absz
Have a vauxhall corsa 1.2 1999 EASYTRONIC GEARBOX the car seems to select gear and drive off at times when in neutral. i have a fault code P1722 (Selection mechanism) but you can here the gearbox trying to engage gear without clutch activator being engaged. you can even here the gearbox crunching into gears even with the engine switched of and car locked :blink:
i don't think its the selector as it seems the ecu is telling it to engage. ANY TIPS ?
  • 3 weeks later...
