Big missfire and naff all power!!!
cloudder
Guys,
Swapped out the plugs, coil and also did the fuel filter (as I had a new one) about a month ago and this seemed to cure the miss-fire. Due to being ill, I didn't get a chance to use the car for more than a few miles and things were 100% good to me. I even popped into my local garage (about 12 miles away as I live in the country) and they quickly did an emmisions test on it and all things are good.
Anyway, came to drive the car today. Started fine, drove about 6 miles, perfect. Orange low fuel light comes on and I am already suspisious that the car is more thursty than usual perhaps. Within a mile, I kicked the auto down to pass another car, the engine stumbled big time and the main warning triangle comes on. Off throttle light goes off but for the next mile the car keeps going from normal, to miss-fire, sometimes to stalled! Luckly my parents house was now within about 1/4 mile so went there. In the drive I could get the engine to about 3900rpm sounding OK, but then a big missfire. Bugger. Also I noted that when coming off throttle, when the idle dropped below 1000rpm, the speedo shot up to about 30mph and then straight back to 0 ?!?!?
Left her there over night. Went back this morning, so the car was cold, with 10 litres of unleaded. Fired her up straight away on the key, but it idled at 800rpm- no cold start sequence of 1500, 1200-1000 down to 750rpm, plus top speed is crawling pace? Any ideas??? HELP!!!
You will probably get a code 42 when you run a diagnostic check ;)
If you do it's likely to be caused by a dry joint/ or a corrupt speed signal in your odometer (there is an easy bypass fix for a corrupt odo which is well documented on here :)).
If that does not solve the issue it might be worth checking if the speed signal wired has been chopped into.
This topic is now closed to further replies.
