cloudder Posted April 25, 2010 Share Posted April 25, 2010 Hi, Can anyone tell me if I can buy a fault code reader to plug into my 1993 mk4 N/A Auto?? Quote Link to comment Share on other sites More sharing options...
devan Posted April 25, 2010 Share Posted April 25, 2010 (edited) You can do it for free by shorting two pins in the 'diagnostics' socket in the engine bay, ill try and find which ones. Edited April 25, 2010 by devan (see edit history) Quote Link to comment Share on other sites More sharing options...
devan Posted April 25, 2010 Share Posted April 25, 2010 Right for my JSpec N/A Manaul you have to short out E1 and TE1 using a short length of cable/wire, so i assume its the same for an Auto (check with somebody else though before you go and carry this out), then you have to turn the ignition key to the second position and the engine management light will flash a certain amount of times and tell you your code, theres a list of fault codes on the forum somewhere. Quote Link to comment Share on other sites More sharing options...
Supranature Posted April 25, 2010 Share Posted April 25, 2010 http://www.mkivsupra.net/vbb/showthread.php?t=35920 Quote Link to comment Share on other sites More sharing options...
cloudder Posted April 25, 2010 Author Share Posted April 25, 2010 Thanks, I'll try this in the next few days. Quote Link to comment Share on other sites More sharing options...
