J spec rear brakes
gavin.starr
This topic may help :)
http://www.mkivsupra.net/vbb/showthread.php?t=215454&highlight=brakes
There were 2 factory brake options on the Supra
Larger Brakes
Front - 4pot Calipers, 323x30mm Discs
Rear - 2pot Calipers, 324x16mm Discs
Smaller Brakes
Front - 2pot Calipers, 296x32mm Discs
Rear - 1pot Calipers, 307x16mm Discs
All UK spec Supras were factory fitted with the larger brakes.
J-spec Supras were factory fitted with either the larger brakes or the smaller brakes, depending on the model and year.
The larger brakes often get referred to as UK brakes, but as they were also factory fitted on many J-spec Supras (actually a lot more than were fitted to UK Supras) the term is confusing.
