Fosta_1 Posted April 24, 2010 Share Posted April 24, 2010 hello supra owners lol it been a while since i last been on here i am hittin a problem with mine and i hope all you supr lovers will help me i been doing a little work on my 1995 n/a supra and the distributor cap got moved and i had to put a new crank shaft pulley on and water pump and i just need to know wat is the timing for the supra to fire please help. does it need to be dead centre to fire or a degree over Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted April 24, 2010 Share Posted April 24, 2010 10 deg btdc Quote Link to comment Share on other sites More sharing options...
Graham S Posted April 24, 2010 Share Posted April 24, 2010 Pretty sure neither of these should be an issue mate... Crank pulley will only fit on in one place, with a little thing called a woodruff key in the crankshaft itself and the pulley has a groove that slots over it. As for the distributor, are you saying the cap moved or the whole dizzy? If its the cap then should only go on one way, again look for the groove. Or are you meaning the leads came off and you need the firing order? Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted April 24, 2010 Share Posted April 24, 2010 if you have moved the whole thing set it at tdc and point the roter at plug 1 Quote Link to comment Share on other sites More sharing options...
Fosta_1 Posted April 24, 2010 Author Share Posted April 24, 2010 thanks for ur reply i did it and a real big thanks for the help it now sorted Quote Link to comment Share on other sites More sharing options...
