Turbos have stopped working
richarde7927
Ok this is a mad one ,i was dropping my son off to football this morning and i put my foot down the turbo's cut in the same as always and then a big back fire and after that car was flat (no power) so i pulled over and the pipe had come off the turbo from the boost controller , so i refitted the pipe and still no turbos im a mechanic so i have looked round to see if there are another pipes off and i cannot see anything wrong .
So the question is what could be the problem there is no smoke from the exhaust , so i do not think the turbo's have blown ,
The car is a j spec rz tt 6 manaul k reg .
Rich.
is there a more definative sound of turbo spool, as when one of my pipes came off you could hear it winding away like crazy as it was just blowing out of the intercooler pipe.
That would make it that there is no presurised airflow from the turbos entering the intake at all and would make it feel like there was no turbos at all.
Happens a lot. Other popular locations are under the battery and under the drivers side headlight :D
FWIW the car doesn't need to smoke when you kill the turbo's. I sheared my turbine wheel clean off and had nothing untoward with regards to exhaust fumes.
If you kill a tubby bearing wise you will get smoke :D
