Homer Posted April 24, 2010 Share Posted April 24, 2010 Fancy selling me a whole set Darryl? If you can't spare a set can you part with an IACV and a EGCV? I have one know good set in a vac sealed bag which I want to keep for myself (sorry), the other set are 'unknown', but can send them if you are stuck. I don't have an IACV though. Without going into detail which controll valve is usually at fault, just so that i can take a look at things propperly with a fresh head in the morning If it's the EG control valve it will be caused by the part that is (poorly) outlined in red in the pic attached. From a troubleshooting point of view it's a single unit and ideally needs to be replaced with a known working one. Is that the part you swapped already? If it was replaced it can be ruled out if the symptoms where exactly the same before and after. Quote Link to comment Share on other sites More sharing options...
Scott Posted April 24, 2010 Share Posted April 24, 2010 I think they are sealed. AFAIK once goosed they get replaced. Haven't seen any guides or information regarding fixing them. Quote Link to comment Share on other sites More sharing options...
Scott Posted April 24, 2010 Share Posted April 24, 2010 I have one know good set in a vac sealed bag which I want to keep for myself (sorry), the other set are 'unknown', but can send them if you are stuck. I don't have an IACV though. If it's the EG control valve it will be caused by the part that is (poorly) outlined in red in the pic attached. From a troubleshooting point of view it's a single unit and ideally needs to be replaced with a known working one. Is that the part you swapped already? If it was replaced it can be ruled out if the symptoms where exactly the same before and after. Ahh I thought you meant the air control valve. Yeah I think the bit you have circled is the bit he has replaced. I had a look at that when my 2nd tubby wasn't firing. Decided just to take the lot off rather than mess around with it. Not a job I would fancy in situ Quote Link to comment Share on other sites More sharing options...
gavin.starr Posted April 26, 2010 Author Share Posted April 26, 2010 Yea the bit you circled in red was the bit that i have changed. ive not had change to look at it this weekend so for now ill keep it in ttc mode. When i have a look some time this week ill keep you both informed as to what it was thats been causing the problem Quote Link to comment Share on other sites More sharing options...
Nic Posted April 26, 2010 Share Posted April 26, 2010 Yea the bit you circled in red was the bit that i have changed. ive not had change to look at it this weekend so for now ill keep it in ttc mode. That's the actuator I had problems with on mine, unfortunately Toyota don't sell them separately (only available new with the turbo). I replaced mine with an HKS one, they don't do a kit specifically for the Supra, but is was quite easy to modify one for a 1JZGTE Chaser. http://www.hks-power.co.jp/products/turbo/act/act.html Quote Link to comment Share on other sites More sharing options...
gavin.starr Posted April 26, 2010 Author Share Posted April 26, 2010 Are they the actuators for the turbos or the actuator that is circled above in homers post. Quote Link to comment Share on other sites More sharing options...
