Guest jackfrosty Posted April 23, 2010 Share Posted April 23, 2010 I have a Jap import 94 N/A Supra, and the air-con doesn't work. I have checked for fault codes by holding down the larger two heater control buttons when turning the ignition on, and I get a fault code flash up. I get: four flashes from all the LEDs, then.. alternate flashing between green recirc LED and amber rear window demist LED. Does anyone know what these codes mean? I can't find it anywhere. Thanks Quote Link to comment Share on other sites More sharing options...
SteveC Posted April 23, 2010 Share Posted April 23, 2010 If it had been April 1st, then I would have thought this air con enquiry was a joke Mr Frosty. Attached is a list of A/C fault codes.Air Con Fault Codes.pdf Quote Link to comment Share on other sites More sharing options...
Guest jackfrosty Posted April 23, 2010 Share Posted April 23, 2010 I'm Jack-Un-Frosty at the moment. No air-con. Thanks for the fault code list, exactly what I was looking for. Do you know which one represents the LED for "grab air from outside", i.e. not recirculate? Cheers Quote Link to comment Share on other sites More sharing options...
SteveC Posted April 23, 2010 Share Posted April 23, 2010 Post or PM me an e-mail address and I'll send you the whole A/C section of the Toyota workshop manual. Quote Link to comment Share on other sites More sharing options...
Guest jackfrosty Posted April 25, 2010 Share Posted April 25, 2010 Problem solved. Well, at least diagnosed. It was the Freshair LED that was flashing, representing low pressure. A leak. What I thought. Thanks Quote Link to comment Share on other sites More sharing options...
Suprab1 Posted April 25, 2010 Share Posted April 25, 2010 I just done this test with mine & got all lights flashing 4 times then the windscreen light flashes. Anyone got any ideas if i have a problem? Sorry but i don't really understand the fault codes. Quote Link to comment Share on other sites More sharing options...
