drift_bear Posted April 23, 2010 Share Posted April 23, 2010 The problem is that when I'm braking I'm hearing a rubbing noise coming from the rears, it sounds like metal rubbin against metal. The car had its mot a couple of weeks ago and it passed with no advisories or anythin. Also when I brake there's a "clicking" noise coming from the front. Does that sound like a brakes problem? any help would be usefull guys (i have the uk brake set up on my jspec) Quote Link to comment Share on other sites More sharing options...
JustGav Posted April 23, 2010 Share Posted April 23, 2010 Have the rattle pins been put in the back pads? Quote Link to comment Share on other sites More sharing options...
Suprab1 Posted April 23, 2010 Share Posted April 23, 2010 I would think you need new rear pads. Quote Link to comment Share on other sites More sharing options...
drift_bear Posted April 24, 2010 Author Share Posted April 24, 2010 Ill be buying new pads all round. I would of thought if the pads were that bad, they would of got picked up on the MOT? Any ideas what could be causing the "clicking" coming from the front brakes? Quote Link to comment Share on other sites More sharing options...
tony tt Posted April 24, 2010 Share Posted April 24, 2010 My fronts use to make an initial click when the pedal was pushed hard. I found when i pushed the pad with my finger (when cold) there was some slight movement from them within the caliper. I bought the anti rattle pins and a new shim kit and it sorted it out. As for the rears sounds like your rear pads have had it mate. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted April 24, 2010 Share Posted April 24, 2010 I had Mintex fast road pads in my UK fronts and they clunked when you applied the brakes. OEM pads have a spring clip I believe which stops this. Quote Link to comment Share on other sites More sharing options...
sams Posted April 24, 2010 Share Posted April 24, 2010 Just because it passed a mot does not mean the brakes were ok, all the mot tests is braking force, I have had a car pass when the pads were metal on metal and had been for 4/5 months, not having a job then cost me for a set of new calipers but I was young and you learn from your mistakes Quote Link to comment Share on other sites More sharing options...
SteveC Posted April 24, 2010 Share Posted April 24, 2010 As above, the MOT doesn't give any real indication of the condition of the brakes at all. All it does is prove the brakes will give a certain level of stopping force - which will be a fraction of what the Supra brakes should be capable of, if in good condition. On my car the brakes passed the MOT OK (I saw the readings on the brake tester), but on the front calipers, 2 of the 4 pistons were seized virtually solid and 1 piston was sticking badly. On top of that, the discs and pads had also seen better days. My guess is that the front brakes were working at around 25% of their full potential, yet it still passed the MOT... Quote Link to comment Share on other sites More sharing options...
