JustGav Posted April 22, 2010 Share Posted April 22, 2010 Spotted this on racecarsdirect... http://www.racecarsdirect.com/listing/29383/BMW_M5M6_V10_Transmission__7speed_Sequential_Gearbox.html http://www.racecarsdirect.com/photos/bmw_kasa_20.jpg Something like that would make an interesting conversion, admittedly the wiring would definitely be a challenge. Link to comment Share on other sites More sharing options...
Miguel Posted April 23, 2010 Share Posted April 23, 2010 A Supra with this type of box would be just about perfect for me . Link to comment Share on other sites More sharing options...
JustGav Posted April 23, 2010 Author Share Posted April 23, 2010 Well, my thinking was and looking at the limited getrag documentation, it is an automatically shifted manual, so gives you the best of both worlds.... The big issue of course is electronic control and the dual clutch option.... makes the bellhousing look like the easy bit I reckon. Link to comment Share on other sites More sharing options...
Gaz6002 Posted April 23, 2010 Share Posted April 23, 2010 I wonder if it comes with a gearbox ECU? If it does, I wonder if someone (Ryan) could work out how to fudge the signals to make it work with a Supra. This sort of mod is right up my street. Shame my wallet disagrees though. I'd LOVE a Supra with a pair of VGT turbos and a DCT box. Perfect Link to comment Share on other sites More sharing options...
Miguel Posted April 23, 2010 Share Posted April 23, 2010 Paulmac and myself have talked about this conversion in the past using the 6 speed SMG II box found in the E46 M3. I believe Paul looked into it as a solution for auto owners not being so restricted on choices. The main problem is that it's not just the Gearbox ECU you have to worry about, but the main ECM too. Both talk to each other via CAN bus and neither will work without the other. So not a small challenge by any means, but not impossible either. So who's going to do it, may come back to the Supra fold then Link to comment Share on other sites More sharing options...
JustGav Posted April 23, 2010 Author Share Posted April 23, 2010 Gaz6002 said: I wonder if it comes with a gearbox ECU? If it does, I wonder if someone (Ryan) could work out how to fudge the signals to make it work with a Supra. This sort of mod is right up my street. Shame my wallet disagrees though. I'd LOVE a Supra with a pair of VGT turbos and a DCT box. Perfect From some brief looking over, it could even be something as simple as actuators pushing it into the various cogs.... Link to comment Share on other sites More sharing options...
JustGav Posted April 23, 2010 Author Share Posted April 23, 2010 Miguel said: Paulmac and myself have talked about this conversion in the past using the 6 speed SMG II box found in the E46 M3. I believe Paul looked into it as a solution for auto owners not being so restricted on choices. The main problem is that it's not just the Gearbox ECU you have to worry about, but the main ECM too. Both talk to each other via CAN bus and neither will work without the other. So not a small challenge by any means, but not impossible either. So who's going to do it, may come back to the Supra fold then Megasquirt handles CANbus (Waits for IanC to start sweating ) Link to comment Share on other sites More sharing options...
Miguel Posted April 23, 2010 Share Posted April 23, 2010 But can it handle the amount of data stream required. It's actually the main ECM that governs the boxes behaviour, the gearbox ECU is just a soldier unit. Link to comment Share on other sites More sharing options...
JustGav Posted April 23, 2010 Author Share Posted April 23, 2010 Miguel said: But can it handle the amount of data stream required. It's actually the main ECM that governs the boxes behaviour, the gearbox ECU is just a soldier unit. I shall have to look into that, I don't have the funds for this sort of project on top of the current one, but I can certainly investigate the theory side of it Link to comment Share on other sites More sharing options...
Gaz6002 Posted April 23, 2010 Share Posted April 23, 2010 So it would require some serious mapping capability then... same as the VGT thing. Would be silly doing one and not the other. When will we see the project thread, Mig? Link to comment Share on other sites More sharing options...
Miguel Posted April 23, 2010 Share Posted April 23, 2010 Gaz6002 said: So it would require some serious mapping capability then... same as the VGT thing. Would be silly doing one and not the other. When will we see the project thread, Mig? Out of the box ideas such as these really do light my fire as they are such a break from the same ol' variations of a theme; But unfortunatley as much as a twin VTG, SMG equipped Supra appeals to me, I just haven't got the facilities to undertake a project of this size anymore. Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 23, 2010 Share Posted April 23, 2010 Does it come with a fork lift to move it ? Can't get my head around why anyone with a 3 litre torquey engine would want seven gears? 5 should be more than enough. Link to comment Share on other sites More sharing options...
Ryan.G Posted April 23, 2010 Share Posted April 23, 2010 Syvecs s6 has full custom canbus control with the ability to be able to set frame indentifiers, frame frequencies and custom content. So im sure it could be made to work. Life racing also have a strategy im sure on there f88 for this type of gearbox which could be implented into the S6 im sure Im tempted! Link to comment Share on other sites More sharing options...
Miguel Posted April 23, 2010 Share Posted April 23, 2010 Go for it Ryan, you know you want to This is what I wanted to discuss with you last year before I sold the Supra. Link to comment Share on other sites More sharing options...
Matt H Posted April 23, 2010 Share Posted April 23, 2010 Chris Wilson said: Does it come with a fork lift to move it ? Can't get my head around why anyone with a 3 litre torquey engine would want seven gears? 5 should be more than enough. If they shift as fast as I hear, wouldn't the fact that they would be in the peak torgue / power band more often be that little bit better? Link to comment Share on other sites More sharing options...
Miguel Posted July 18, 2011 Share Posted July 18, 2011 Bored twiddling my thumbs today, so after watching the GTR on top gear the thought of an DSG/SMG Supra popped into my head again. So, anyone done anything like this yet? Link to comment Share on other sites More sharing options...
Ian C Posted July 18, 2011 Share Posted July 18, 2011 How hard can it be, eh? Link to comment Share on other sites More sharing options...
Miguel Posted July 18, 2011 Share Posted July 18, 2011 Ian C said: How hard can it be, eh? That's the million dollar question. Link to comment Share on other sites More sharing options...
caseys Posted July 18, 2011 Share Posted July 18, 2011 Ian C said: How hard can it be, eh? I imagined that in a Clarkson "How hard can it be?" voice Link to comment Share on other sites More sharing options...
Kirk Posted July 18, 2011 Share Posted July 18, 2011 The idea sounds great BUT how well can these transmissions cope with the power your average single kicks out? Link to comment Share on other sites More sharing options...
Miguel Posted July 18, 2011 Share Posted July 18, 2011 m_life said: The idea sounds great BUT how well can these transmissions cope with the power your average single kicks out? There would only be one way to really answer that as there are too few cases of big power SMG's, for example, to make a comparison. A couple of companies like HPF have largish HP SMG M3's running, but I don't class a few short bursts up a drag strip to be the measure of reliability. I wouldn't be surprised if they handle more than we think though considering most of their internals are based on a manual box design; after all, on paper the V160 shouldn't stand up to the power that some Supra owners throw though it, but it does. Link to comment Share on other sites More sharing options...
