Rattle from clutch / flywheel
fuldhat
Hi.
I have a 93 TT6 with a stock flywheel and clutch ( I presume)
When you start it up from cold, then all is normal and no rattle.
Then after you have driven a good trip and park it, there is a rattle from the gearbox, if I push the clutch pedal down, then the rattle is disappears.
Sometimes though, when you park it after a drive, then there is no rattle, and then after a little while, the rattle begins.
What to here?...:)
Okay... Will this cause more wear on bearings and such?
What is the price for an OEM toyota flywheel in the UK?
I will check the price for a new one at toyota on monday in denmark, but it might be cheaper to buy in the UK, so if anyone knows the price, that would be cool..:)
And then I might as well change the clutch aswell to new one.
In Bulgaria the original TT flywheel is 234euro, no need to return your old one.
That's actually what I bought and changed recently.
9006908001 SEALING 21.00
9008031031 SEAL,TYPE T OIL 11.84
9008031029 SEAL,TYPE T OIL 19.77
9671124030 RING 2.30
9046721010 CLIP 2.48
3123114050 HUB, CLUTCH REL 39.21
3126414060 SPRING, CLUTCH 2.73
9056050001 SPACER 5.46
9052075001 RING, SNAP 2.78
9020612006 WASHER, WAVE 1.48
9056079001 SPACER 2.25
9036312002 BEARING,BAL,12, 5.80
3125014200 DISC ASSY, CLUTCH 102.17
9615200500 RING, SNAP 2.48
9090363001 BALL, BEARING 74.55
3121014180 COVER ASSY, CLUTCH147.42
0431314040 n/a 0.00
3147014070 n/a 0.00
0431160150 CYLINDER KIT, C 31.32
3141014300 CYLINDER ASSY 109.77
3148114240 n/a
3148214050 n/a
3148215060 n/a
Divide the prices by 2 and you will get in EURO.
Just that I took
DISC ASSY, CLUTCH
COVER ASSY, CLUTCH
for TT, which are 45euro more.
Those are original from Toyota.
Thanks. Good to know to prices in other countries.
0431314040 n/a 0.00
3147014070 n/a 0.00
3148114240 n/a
3148214050 n/a
3148215060 n/a
Just that I took
DISC ASSY, CLUTCH
COVER ASSY, CLUTCH
Well the gearbox works perfect and the whole car has only done 65000 miles.
Could be a worn gearbox. Pressing the clutch pedal stops the gearbox internals turning. They aren't the quietest of things with some miles on them. The dual mass flywheel can be tested for wear with the gearbox off.
