gaz1 Posted April 22, 2010 Share Posted April 22, 2010 having a mare trying to connect my cinema surround system, almost done but the optical lead just will not go into the back of the sky box, is there a special way to connect this as i have been trying to push it in very hard and it will not go in all the way, and stay in:( Link to comment Share on other sites More sharing options...
Luxluc Posted April 22, 2010 Share Posted April 22, 2010 Do you have a pic of the connector and the logging. Normally, optical connectors fit quite smoothly (So did mine) .. and shouldn't be forced. Link to comment Share on other sites More sharing options...
probrox Posted April 22, 2010 Share Posted April 22, 2010 Is it a new cable and if so have you taken the plastic cover off of the end of the cable? Also, they're flat on one side so have to go in the right way round. Link to comment Share on other sites More sharing options...
gaz1 Posted April 22, 2010 Author Share Posted April 22, 2010 Is it a new cable and if so have you taken the plastic cover off of the end of the cable? Also, they're flat on one side so have to go in the right way round. i did not realize the little rubber ends come off:innocent: sorted thanks mate 1 more little niggle, it sounds fantastic with the bd disc, but when i swap to sky movies i only get the tv sound, nothing from surround sound, its probably me doing something wrong again any thoughts Link to comment Share on other sites More sharing options...
The Raven Posted April 22, 2010 Share Posted April 22, 2010 There will be a button to turn the SS from 2.1 to 5.1 at a guess. Link to comment Share on other sites More sharing options...
Stu_Fraser Posted April 22, 2010 Share Posted April 22, 2010 i did not realize the little rubber ends come off:innocent: sorted thanks mate 1 more little niggle, it sounds fantastic with the bd disc, but when i swap to sky movies i only get the tv sound, nothing from surround sound, its probably me doing something wrong again any thoughts Have you changed your settings on the sky box to transmit surround sound? Also not all programs come with DD surround sound, look for DD in the top right hand corner when you press the program info Link to comment Share on other sites More sharing options...
Luxluc Posted April 22, 2010 Share Posted April 22, 2010 i did not realize the little rubber ends come off:innocent: sorted thanks mate 1 more little niggle, it sounds fantastic with the bd disc, but when i swap to sky movies i only get the tv sound, nothing from surround sound, its probably me doing something wrong again any thoughts On my system, I have to get into the right input in order to get the sound from the TV. Check on your's .. you will have to be on optical input on the home cinema system. Link to comment Share on other sites More sharing options...
gaz1 Posted April 22, 2010 Author Share Posted April 22, 2010 On my system, I have to get into the right input in order to get the sound from the TV. Check on your's .. you will have to be on optical input on the home cinema system. i am stumped, i have the sky hdmi to the tv, the sky optical to the surround system, the surround hdmi is connected to the tv, the sky is set on dolby digital, the sky movie is dd the blueray discs sound superb, but sky will still only play through the tv speakers, i changed the tv sound mode to external speakers and then i get no sound at all:search: Link to comment Share on other sites More sharing options...
JustGav Posted April 22, 2010 Share Posted April 22, 2010 i am stumped, i have the sky hdmi to the tv, the sky optical to the surround system, the surround hdmi is connected to the tv, the sky is set on dolby digital, the sky movie is dd the blueray discs sound superb, but sky will still only play through the tv speakers, i changed the tv sound mode to external speakers and then i get no sound at all:search: Does your tv have an optical out? if so use that rather the sky out. The digital sound from sky is transmitted down the HDMI to the telly. So by plugging the optical into the telly rather, you will get what ever the telly is pushing out and it means less things to change when you change channel Link to comment Share on other sites More sharing options...
Luxluc Posted April 22, 2010 Share Posted April 22, 2010 Does your tv have an optical out? if so use that rather the sky out. The digital sound from sky is transmitted down the HDMI to the telly. So by plugging the optical into the telly rather, you will get what ever the telly is pushing out and it means less things to change when you change channel I confirm. My Optical cable goes from the TV to the home cinema. Link to comment Share on other sites More sharing options...
gaz1 Posted April 22, 2010 Author Share Posted April 22, 2010 Does your tv have an optical out? if so use that rather the sky out. The digital sound from sky is transmitted down the HDMI to the telly. So by plugging the optical into the telly rather, you will get what ever the telly is pushing out and it means less things to change when you change channel thanks gav, spot on:D Link to comment Share on other sites More sharing options...
scotty71 Posted April 22, 2010 Share Posted April 22, 2010 i did not realize the little rubber ends come off:innocent: DEADLY lol:d Link to comment Share on other sites More sharing options...
