jevansio Posted April 22, 2010 Share Posted April 22, 2010 Woke up today to a light frost so I thought I'd take the Supe to work to see if I could beat my 583rwhp score. Iphone showed 0 deg outside, it was dry & sunny so "perfect" conditions. So once warmed up I did my first run 558rwhp, mmm down a bit, proceeded to do 3 more runs (recording the boost on the defi's to check I was seeing full boost to the redline - which I was), all 3 runs came in at or around 555rwhp. So I noticed my WI was on (which Ryan had told me to turn off during tuning - but I turned back on the other day as I had just filled up the new plastic tank with 50/50 water/methanol). I turned this off & did another run, 591rwhp , a personal best . Just posting this as it's hard data & may be of use to someone, but for me proves that if your car isn't mapped to take the advantages of WI & you don't need it, the it's just sapping power (even if it is a methanol mix) Link to comment Share on other sites More sharing options...
sdistc Posted April 22, 2010 Share Posted April 22, 2010 Nice. Link to comment Share on other sites More sharing options...
suprafan72 Posted April 22, 2010 Share Posted April 22, 2010 Woke up today to a light frost so I thought I'd take the Supe to work to see if I could beat my 583rwhp score. Iphone showed 0 deg outside, it was dry & sunny so "perfect" conditions. So once warmed up I did my first run 558rwhp, mmm down a bit, proceeded to do 3 more runs (recording the boost on the defi's to check I was seeing full boost to the redline - which I was), all 3 runs came in at or around 555rwhp. So I noticed my WI was on (which Ryan had told me to turn off during tuning - but I turned back on the other day as I had just filled up the new plastic tank with 50/50 water/methanol). I turned this off & did another run, 591rwhp , a personal best . Just posting this as it's hard data & may be of use to someone, but for me proves that if your car isn't mapped to take the advantages of WI & you don't need it, the it's just sapping power (even if it is a methanol mix) Be interesting for you to try it when its 23 to 24 deg outside..... I would only use this at very high boost on a hot day... Im sure Chris W could give some input here? Link to comment Share on other sites More sharing options...
jevansio Posted April 22, 2010 Author Share Posted April 22, 2010 Be interesting for you to try it when its 23 to 24 deg outside..... I would only use this at very high boost on a hot day... Im sure Chris W could give some input here? Yeah, I thought that too (and will try it again in the summer & update this thread) Link to comment Share on other sites More sharing options...
Wez Posted April 22, 2010 Share Posted April 22, 2010 What WI system are you using, what size jets and where are the placed, you may be injecting too much. Do you have record of the difference in AFR with and without WI enabled. Link to comment Share on other sites More sharing options...
jevansio Posted April 22, 2010 Author Share Posted April 22, 2010 What WI system are you using, what size jets and where are the placed, you may be injecting too much. Do you have record of the difference in AFR with and without WI enabled. Aquamist 1S, triggered at 10PSI, just changed to the .9mm jet (the one recommended for Supras, I do have the smaller one I used to run) I don't bud but I can get it next time I'm logging with the laptop Link to comment Share on other sites More sharing options...
dandan Posted April 22, 2010 Share Posted April 22, 2010 Where's the jet Jay? Link to comment Share on other sites More sharing options...
JamieP Posted April 22, 2010 Share Posted April 22, 2010 Same as mine mate, always feels slower with the WI on, never use it anymore, infact im going to remove it. Link to comment Share on other sites More sharing options...
dandan Posted April 22, 2010 Share Posted April 22, 2010 Most likely is too much water. Link to comment Share on other sites More sharing options...
jevansio Posted April 22, 2010 Author Share Posted April 22, 2010 Right after the FMIC Dan, will do more tests with a smaller jet too Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted April 22, 2010 Share Posted April 22, 2010 Yep too much water i would say, you are using the pressure operated system which basically gives you 100% of what the jet can pass all the time its on, you need it on a mappable HSV to take proper advantage. Also what are you using to measure and log the BHP with Jay? as most of them are not that accurate. Link to comment Share on other sites More sharing options...
jevansio Posted April 22, 2010 Author Share Posted April 22, 2010 Yep too much water i would say, you are using the pressure operated system which basically gives you 100% of what the jet can pass all the time its on, you need it on a mappable HSV to take proper advantage. Also what are you using to measure and log the BHP with Jay? as most of them are not that accurate. Will try again with a smaller jet bud It's the Racelogic Performance Box Link to comment Share on other sites More sharing options...
imi Posted April 22, 2010 Share Posted April 22, 2010 On SRR my car ran 555bhp without WI and with WI it ran 564bhp (Ryan increased the boost a bit - i think). Everything else on the car was exactly the same including the plugs. This took place on 2 separate occasions (over a year apart) so weather, fuel, tyre pressures, etc could play a roll too. Link to comment Share on other sites More sharing options...
Luxluc Posted April 22, 2010 Share Posted April 22, 2010 591 rwhp is mighty impressive Jay. Outside temperature (like the 0°C you had) plays an important role on the power curve. Correct me if I'm wrong, but I thought that the main reason for WI was to be able to run safer higher boosts. So I guess, putting WI on alone won't bring any benefit ... or am I wrong?? Link to comment Share on other sites More sharing options...
jevansio Posted April 22, 2010 Author Share Posted April 22, 2010 OK, been out and swapped my other 0.5mm jet in (the smallest jet aquamist does). Results weren't as conclusive, I first did 2 runs with WI, it showed 535 & 537rwhp. Then without WI I did 2 runs showing 555rwhp (it was upto around 13 deg ambient so I guess that's why it was down from the morning). I then did another run with just to show it had gone back down & lo & behold it showed 556rwhp. I need to do some more tests I think now or even better get it on a dyno. The runs this evening felt a lot closer in terms of arse dyno too, compared to this morning where the you could feel it pull stronger without. Either way I don't think even the smallest amount of water & meth that is possible to be injected with the 1S system is actually "adding" any performance to the car, again this is all IMHO. Link to comment Share on other sites More sharing options...
jevansio Posted April 22, 2010 Author Share Posted April 22, 2010 591 rwhp is mighty impressive Jay. Outside temperature (like the 0°C you had) plays an important role on the power curve. Correct me if I'm wrong, but I thought that the main reason for WI was to be able to run safer higher boosts. So I guess, putting WI on alone won't bring any benefit ... or am I wrong?? I dunno Luc, I've read all sorts on the benefits from cooling the charge before it enters the cylinder, to actual in cylinder cooling & the obvious det protection of using meth. My EGT's didn't chage from the before & after (well not enough for me to notice on the gauge anyway) I only ran these tests for my own benefit (as I hate taking for granted what people tell me). Things I know for sure are an 0.9mm jet is too big. Link to comment Share on other sites More sharing options...
Scott Posted April 22, 2010 Share Posted April 22, 2010 I didn't think WI did add to the performance? I thought it only allowed an increase in boost safely? The fact the charge is cooler allows you to pack more of it in? Link to comment Share on other sites More sharing options...
jevansio Posted April 22, 2010 Author Share Posted April 22, 2010 (edited) I didn't think WI did add to the performance? I thought it only allowed an increase in boost safely? The fact the charge is cooler allows you to pack more of it in? Dunno bud, I was always under the impression that injecting a small amount of water/meth would give a performance increase even without upping the boost (due to the cooling of the charge & the increased octane in the cylinder & cooler cylinder temps). I'm going to dig out that large chunk of text that often gets pasted from the aquamist site & re-read it EDIT this is one of the threads http://www.mkivsupra.net/vbb/showthread.php?t=96560&highlight=water+injection+benefits PS I'm not a WI basher, I just like to put figures onto things to prove they do what they are supposed to do. I'm starting to wonder after re-reading that thread that the major benefits of the WI will start to show in the summer & the cooling properties aren't good enough in this already cool weather. I also need to verify the RLPB to see if I can get a graph of bhp from it as if bhp is climbing when I reach the redline the results will vary depending on how soon I lift off I will get the data I want though Edited April 22, 2010 by jevansio (see edit history) Link to comment Share on other sites More sharing options...
Wez Posted April 22, 2010 Share Posted April 22, 2010 Either way I don't think even the smallest amount of water & meth that is possible to be injected with the 1S system is actually "adding" any performance to the car They way yours is setup its not supposed to add performance, unless you have mapped the car to take advantage of the added octane and cooling, ie more boost and ignition timing you will not see any gains. When installed like most have them they are a safety net. Link to comment Share on other sites More sharing options...
