Greddy bcc
Guest jonte_j
Guest jonte_j
Im installing bpu on my car wich is a -94 j-spec. When i was going to install bcc i found two other gadgets plugged in to the ecu! What do they do, and can i remove them?
Edited by jonte_j (see edit history)
Guest jonte_j
i might be able to tell you what they are, but what i need to know is what colour wire and plug on your ecu are the devices connected to, regards chris
Thanks, i will look it up!
