catfish man Posted April 20, 2010 Share Posted April 20, 2010 anyone had problems removing the LOWER Boot Lid/Tail Gate Rubber stops-? my lower boot lid rubbers have lost the will to live so i got some new ones only to find out the screws heads have been rounded via a previous owner i would think anyone know how do i remove them in this condition? i have new screws with the new rubber stops cheers chaps:innocent: Quote Link to comment Share on other sites More sharing options...
ScottC Posted April 20, 2010 Share Posted April 20, 2010 (edited) Toyota really made sure these wouldn't come loose. I had to heat mine up with a hairdryer to soften the thread lock. If you removed the damaged rubbers could you attack the screw heads with a pair of grips? Edited April 20, 2010 by ScottC (see edit history) Quote Link to comment Share on other sites More sharing options...
evinX Posted April 20, 2010 Share Posted April 20, 2010 I hear they were just siliconed in, and was told to put a solder iron on the bolt to heat it up + the silicone which will let them both come free? Quote Link to comment Share on other sites More sharing options...
catfish man Posted April 20, 2010 Author Share Posted April 20, 2010 (edited) Toyota really made sure these wouldn't come loose. I had to heat mine up with a hairdryer to soften the thread lock. If you removed the damaged rubbers could you attack the screw heads with a pair if grips? hairdryer thats me out im bald and my x-wife did not leave her hair dryer lol:d yea the rubbers are off i thought it would be a 5 min qiuck job in my lunch break will try with the grips and let you know how i got on cheers Edited April 20, 2010 by catfish man (see edit history) Quote Link to comment Share on other sites More sharing options...
catfish man Posted April 20, 2010 Author Share Posted April 20, 2010 I hear they were just siliconed in, and was told to put a solder iron on the bolt to heat it up + the silicone which will let them both come free? i have a solder iron thanks for the tip i will give it a try Quote Link to comment Share on other sites More sharing options...
foggy147 Posted April 20, 2010 Share Posted April 20, 2010 Yes they are a pain I couldnt get my bottom ones off. All you have to do is take the top ones off and add an extra washer and put the top ones back on. It should then be enough to push down on the bottom ones more Quote Link to comment Share on other sites More sharing options...
catfish man Posted April 20, 2010 Author Share Posted April 20, 2010 Yes they are a pain I couldnt get my bottom ones off. All you have to do is take the top ones off and add an extra washer and put the top ones back on. It should then be enough to push down on the bottom ones more i dont understand my top ones are fine? Quote Link to comment Share on other sites More sharing options...
foggy147 Posted April 20, 2010 Share Posted April 20, 2010 i dont understand my top ones are fine? Are you bottom ones just worn a bit so it rattles when driving? Quote Link to comment Share on other sites More sharing options...
catfish man Posted April 20, 2010 Author Share Posted April 20, 2010 Are you bottom ones just worn a bit so it rattles when driving? no the rubbers have falling apart with old age? only got the screws fitted to both sides pulled of the old rubber Quote Link to comment Share on other sites More sharing options...
Guest blueangel Posted April 20, 2010 Share Posted April 20, 2010 ive tried with an impact srewdriver to get mine out gonna use heat next Quote Link to comment Share on other sites More sharing options...
Homer Posted April 20, 2010 Share Posted April 20, 2010 The bolts can be a real pain to remove on the lowers. If they round, they use a hacksaw blade to cut a line into the both head and use a large flat head screw driver to remove. They will come straight out, had to do that on all but one car I've replaced them on! Quote Link to comment Share on other sites More sharing options...
evinX Posted April 20, 2010 Share Posted April 20, 2010 While were on this subject, im going to need to do mine soon with my respray, how much can i get them for with the bolts and where from? have a feeling toyota might want to overcharge for these little bits.. Quote Link to comment Share on other sites More sharing options...
foggy147 Posted April 20, 2010 Share Posted April 20, 2010 Whifbitz do them it cost me about £26 with bolts and delivery Quote Link to comment Share on other sites More sharing options...
evinX Posted April 20, 2010 Share Posted April 20, 2010 Whifbitz do them it cost me about £26 with bolts and delivery thankyou mate:) Quote Link to comment Share on other sites More sharing options...
catfish man Posted April 20, 2010 Author Share Posted April 20, 2010 While were on this subject, im going to need to do mine soon with my respray, how much can i get them for with the bolts and where from? have a feeling toyota might want to overcharge for these little bits..£13 for the 2 posted on ebay and they are original toyota parts i can pm you the details Quote Link to comment Share on other sites More sharing options...
evinX Posted April 21, 2010 Share Posted April 21, 2010 £13 for the 2 posted on ebay and they are original toyota parts i can pm you the details cheers bud, im going to get them soon:) Quote Link to comment Share on other sites More sharing options...
fri3ndly Posted December 11, 2011 Share Posted December 11, 2011 Sorry to reactivate a new thread but this afternoon I tried replacing these lower boot rubbers with some new ones and ran into a problem. I heated up one screw and that one came out fine, the other screw was an absolute pain in the backside. I held the soldering iron on it for ages and eventually the more and more I twisted it out with the screw driver the more rounded it became. It is a total mess now - I also had a go at cutting a new head with a hacksaw blade, but don't want to ruin the metal surround lip which sits at the same level as the screw head - any ideas? It was all going so well at first haha Quote Link to comment Share on other sites More sharing options...
