help with a boost pipe
Baz018
Guest beathacker
Do you need that hose ? or could you connect the evc to that ?
As i dont have any pipe connection on my turbo..
It goes to a hardline that goes across the bulkhead, ending up at the rear-most connection on the charcoal cannister.
Ah rite thanks, mine was a n/a so thats why i wont have the hardline on the bulkhead. Im guessing it connects to the bottom of the cannister.
The line is there on an NA, just in a different place due to the intake system. You can just block it off though, it won't cause any issue other than making the engine bay smell of a little bit of fuel from time to time.
