how to stop the annoying bong sound when the door is open?
Lude
Anybody know if this fuse will also stop the constant high-pitched noise when you leave the lights on and open the door.
Ill remove the fuse if it only stops the bonging noise which lets you know the keys are in the ignition, but if it also stops the lights left on warning noise ill leave it.
Guest SupraGTE
from the ignition lock is coming a cable with a 2 pin black connector ,there is a blue one also that looks the same, the blue one is for light around the ignition lock disconnect the black one and voila its is gone :), u need to remove the lower cover thats sits with 2 m6 screws
