JODY T Posted April 18, 2010 Share Posted April 18, 2010 (edited) Just found this info, prob gonna be of use to someone somewhere 93-96 Toyota Supra Replacement Light Bulb Size Guide Low Beam Headlight Bulb Size: 9006 High Beam Headlamp Light Bulb Size: 9005 Parking Light Bulb Size: 168 Front Turn Signal Light Bulb Size: 1156 Rear Turn Signal Light Bulb Size: 1156 Tail Light Bulb Size: 1157 Stop Light Bulb Size: 1157 High Mount Stop Light Bulb Size: Assembly Fog/Driving Light Bulb Size: H3-55W License Plate Light Bulb Size: 168 Back Up Light Bulb Size: 1156 Front Side Marker Light Bulb Size: 194 Rear Sidemarker Light Bulb Size: 194 Glove Box Light Bulb Size: 37 or 74 Trunk/Cargo Area Light Bulb Size: 194 or DE3022 Instrument-General Light Bulb Size: 194 or 74 Facelift 96-02 Toyota Supra Car Light Bulb Size Guide Low Beam Headlight Bulb Size: 9006 High Beam Headlamp Light Bulb Size: 9005 Parking Light Bulb Size: 2825 Front Turn Signal Light Bulb Size: 7440 Rear Turn Signal Light Bulb Size: 7440 Tail Light Bulb Size: 7443 Stop Light Bulb Size: 7443 High Mount Stop Light Bulb Size: Assembly Fog/Driving Light Bulb Size: H3-55W License Plate Light Bulb Size: 2825 Back Up Light Bulb Size: 7440 Front Side Marker Light Bulb Size: 194 Rear Sidemarker Light Bulb Size: 194 Glove Box Light Bulb Size: 37 Trunk/Cargo Area Light Bulb Size: DE3022 Instrument-General Light Bulb Size: 194 or 74 Edited April 18, 2010 by JODY T (see edit history) Quote Link to comment Share on other sites More sharing options...
Westy Posted October 1, 2012 Share Posted October 1, 2012 Front Turn Signal Light Bulb Size: 7440 (T20) Thanks. Quote Link to comment Share on other sites More sharing options...
Ian C Posted October 1, 2012 Share Posted October 1, 2012 Poached for tech Quote Link to comment Share on other sites More sharing options...
SupraDan24 Posted October 2, 2012 Share Posted October 2, 2012 Any chance you have the same for UK spec Jody? Quote Link to comment Share on other sites More sharing options...
Westy Posted October 5, 2012 Share Posted October 5, 2012 Facelift Low Beam Headlight Bulb Size: 9006 High Beam Headlamp Light Bulb Size: 9005 Confirmed as I found out to my peril buying a 9005 HID kit in the GB. Hopefully the seller will exchange. Quote Link to comment Share on other sites More sharing options...
SupraDan24 Posted October 16, 2012 Share Posted October 16, 2012 westy882 said: Facelift Low Beam Headlight Bulb Size: 9006 High Beam Headlamp Light Bulb Size: 9005 Confirmed as I found out to my peril buying a 9005 HID kit in the GB. Hopefully the seller will exchange. There not all like that though Westy. If it makes you feel any better, i've just removed my facelift lights and they are the same as yours Fortunately i'm fitting UK spec headlights though, so the difference in bulbs worked in my favour Quote Link to comment Share on other sites More sharing options...
TubbyTwo Posted October 16, 2012 Share Posted October 16, 2012 Dont forget that if its for a Jspec car, the tabs in the bulbs need removing: Quote Link to comment Share on other sites More sharing options...
gordy.r Posted June 21, 2016 Share Posted June 21, 2016 Ok.... so whilst searching I came across this and was also pointed in the direction of this thread. It seems a bit of a minefield when googling online which dipped/low beam HID kit to buy for a 1994 jspec supra, the variations and advice vary on whether it is an H3 or H4 buld/kit required, but all agree that it is the 9006. So just before I part with my hard earned cash.... is this the correct kit I am looking for? http://www.hids-direct.co.uk/ultra-9006-hb4-35w-slim-canbus-hid-xenon-conversion-kit/ Many thanks in advance for any help offered Quote Link to comment Share on other sites More sharing options...
gordy.r Posted June 22, 2016 Share Posted June 22, 2016 Or.... what about this set.... http://www.hids4u.co.uk/HB3-9005-HIDS4U-Stealth-35W-Xenon-HID-Conversion-Kit.html Quote Link to comment Share on other sites More sharing options...
Jellybean Posted July 13, 2017 Share Posted July 13, 2017 Facelifts on mine are hb3 high and low beam Quote Link to comment Share on other sites More sharing options...
wile e coyote Posted November 19, 2017 Share Posted November 19, 2017 Thread revival Anybody had any success with led bulbs in the dip and main beam ? Led technology must have come on a lot now If so what make and lumina's you got/ recommend ? Quote Link to comment Share on other sites More sharing options...
clay Posted November 19, 2017 Share Posted November 19, 2017 the HID headlight bulbs have gone on mine. what are people using these days. j spec pre facelift. Quote Link to comment Share on other sites More sharing options...
Jellybean Posted November 20, 2017 Share Posted November 20, 2017 I cannot fault NightEye LEDs https://www.ebay.co.uk/itm/2x-NIGHTEYE-8000LM-9005-9006-H4-H7-H11-LED-Headlight-Kit-Bulb-Fog-Light-Lamp/253154931459?hash=item3af135b303:m:m1mhDhalt0OC0k_r-qgoo3Q Quote Link to comment Share on other sites More sharing options...
Rashed Posted August 12, 2018 Share Posted August 12, 2018 Can anyone confirm what size headlamp LED bulbs are needed for a year 2000 facelift J spec car? Low/highbeam and front fog lights. Many thanks, it all seems a minefield to me at the moment. I will be opting for the NightEye brand as I seem to hear good things about them. Quote Link to comment Share on other sites More sharing options...
Jellybean Posted August 12, 2018 Share Posted August 12, 2018 If you look at the lens on your headlight , should say HB3 Using Nighteya over a year now , great value and light Quote Link to comment Share on other sites More sharing options...
Rashed Posted August 12, 2018 Share Posted August 12, 2018 Jellybean said: If you look at the lens on your headlight , should say HB3 Using Nighteya over a year now , great value and light Thanks man! Really appreciate it. Is that HB3 for the low, high or fog? Quote Link to comment Share on other sites More sharing options...
Jellybean Posted August 12, 2018 Share Posted August 12, 2018 Rashed said: Thanks man! Really appreciate it. Is that HB3 for the low, high or fog? low as in headlight you us at night, its near the corner of the lense Quote Link to comment Share on other sites More sharing options...
Rashed Posted August 12, 2018 Share Posted August 12, 2018 Just had a look at my year 2000 J spec facelift VVTi car. Front fog = H3 12V55W Low beam = HB4 9006J 12V55W High beam = HB3 9005 12V55W Quote Link to comment Share on other sites More sharing options...
ianhid Posted September 6, 2018 Share Posted September 6, 2018 For anyone else finding this, the 9006J variant bulb is narrower than the normal 9006 and you can't really get them in the UK, a normal 9006 will not fit. Use a 9005 instead, you'll have to trim a small plastic tab out of the inside of the connector plug to get them to fit. As a slight bonus, 9005's are more powerful. Quote Link to comment Share on other sites More sharing options...
Nathanj1142 Posted March 20, 2019 Share Posted March 20, 2019 I’m struggling to find what bulbs go in the interior light on the roof, is it t5? Quote Link to comment Share on other sites More sharing options...
Burna Posted March 20, 2019 Share Posted March 20, 2019 (edited) Nathanj1142 said: I’m struggling to find what bulbs go in the interior light on the roof, is it t5? Here you go: https://www.ebay.co.uk/itm/Lucas-LLB233-12V-4W-Sidelight-Bulb-T4W-BA9S-Pack-of-10-LUCAS-TEN-PACK/113370862042?hash=item1a656e11da:g:mUkAAOSwsDZb6uJK Or if you want to update them to LED's: https://www.ebay.co.uk/itm/Led-White-BA9S-233-T4W-Smd-Interior-Side-Light-Bulbs-Lamps-Canbus-No-Error-12V/153038711524?_trkparms=aid%3D555018%26algo%3DPL.SIM%26ao%3D1%26asc%3D20190212102350%26meid%3Debe380ce30804257926ea8a4f146d32f%26pid%3D100012%26rk%3D5%26rkt%3D5%26sd%3D140615448859%26itm%3D153038711524&_trksid=p2047675.c100012.m1985 Edited March 20, 2019 by Burna (see edit history) Quote Link to comment Share on other sites More sharing options...
Nathanj1142 Posted March 21, 2019 Share Posted March 21, 2019 Burna said: Here you go: https://www.ebay.co.uk/itm/Lucas-LLB233-12V-4W-Sidelight-Bulb-T4W-BA9S-Pack-of-10-LUCAS-TEN-PACK/113370862042?hash=item1a656e11da:g:mUkAAOSwsDZb6uJK Or if you want to update them to LED's: https://www.ebay.co.uk/itm/Led-White-BA9S-233-T4W-Smd-Interior-Side-Light-Bulbs-Lamps-Canbus-No-Error-12V/153038711524?_trkparms=aid%3D555018%26algo%3DPL.SIM%26ao%3D1%26asc%3D20190212102350%26meid%3Debe380ce30804257926ea8a4f146d32f%26pid%3D100012%26rk%3D5%26rkt%3D5%26sd%3D140615448859%26itm%3D153038711524&_trksid=p2047675.c100012.m1985 Cheers mate, ordered some LED ones. Quote Link to comment Share on other sites More sharing options...
Rashed Posted June 26, 2020 Share Posted June 26, 2020 Is anyone able to tell me the equivalent/alternative for Parking Light Bulb Size: 2825 on a facelift car? Many thanks! Quote Link to comment Share on other sites More sharing options...
Konrad Posted May 11, 2021 Share Posted May 11, 2021 Tiny bulbs found inside of climate control are t1 bulbs with 4mm diameter. 1 Quote Link to comment Share on other sites More sharing options...
supra-ireland Posted September 2, 2022 Share Posted September 2, 2022 (edited) This might need to be updated as I don't think 9006 will fit for jspec dipped headlights. I think they should be 9006J, or need to be a modified 9005 / 9006. In fact. I've just fitted a 9005 into a jspec facelift dipped headlight socket, without trimming tabs or altering it in any way. Edited September 3, 2022 by supra-ireland (see edit history) Quote Link to comment Share on other sites More sharing options...
