sauron Posted April 17, 2010 Share Posted April 17, 2010 Trying to remove auto gear lever so i can change the selector panel.have removed the plastic surrounds and undone the 4 x screws underneath that fix the whole assembly down,Cannot see how the gear lever is removed??? Link to comment Share on other sites More sharing options...
Guest beathacker Posted April 23, 2010 Share Posted April 23, 2010 Need some info about this to anybody ? Link to comment Share on other sites More sharing options...
Matt H Posted April 23, 2010 Share Posted April 23, 2010 Trying to remove auto gear lever so i can change the selector panel.have removed the plastic surrounds and undone the 4 x screws underneath that fix the whole assembly down,Cannot see how the gear lever is removed??? Edit, I've done this actually, when I replaced the leather on mine. From memory, the thing that holds it in now is the buttons . You need to pull those out (can't remember how) and the the leaver is freed. Link to comment Share on other sites More sharing options...
Swampy442 Posted April 23, 2010 Share Posted April 23, 2010 You mean the lever with the O/D swithc etc on it? Put the lever in N, below the leather part is a plastic cover, slide this down to reveal 2 cross head screws, undo the screws and pull the lever off. Link to comment Share on other sites More sharing options...
mark newman Posted April 23, 2010 Share Posted April 23, 2010 You mean the lever with the O/D swithc etc on it? Put the lever in N, below the leather part is a plastic cover, slide this down to reveal 2 cross head screws, undo the screws and pull the lever off. That's it , I think you also have to disconect the O/D wire from the button to totaly remove the lever. Link to comment Share on other sites More sharing options...
Swampy442 Posted April 23, 2010 Share Posted April 23, 2010 Nope, its all integral, just slide it off/on. Link to comment Share on other sites More sharing options...
Matt H Posted April 24, 2010 Share Posted April 24, 2010 That's it , I think you also have to disconect the O/D wire from the button to totaly remove the lever. Nope, its all integral, just slide it off/on. i Certainly had to remove the OD button or something from memory Link to comment Share on other sites More sharing options...
Swampy442 Posted April 24, 2010 Share Posted April 24, 2010 I dont see how its any different between the Aristo and the Supra. Go and try it Link to comment Share on other sites More sharing options...
