How do i remove auto gear lever??
sauron
Trying to remove auto gear lever so i can change the selector panel.have removed the plastic surrounds and undone the 4 x screws underneath that fix the whole assembly down,Cannot see how the gear lever is removed???:rolleyes:
Edit,
I've done this actually, when I replaced the leather on mine.
From memory, the thing that holds it in now is the buttons . You need to pull those out (can't remember how) and the the leaver is freed.
You mean the lever with the O/D swithc etc on it?
Put the lever in N, below the leather part is a plastic cover, slide this down to reveal 2 cross head screws, undo the screws and pull the lever off.
That's it :thumbs:, I think you also have to disconect the O/D wire from the button to totaly remove the lever.
