Timing question
Terminator
Doubt this will help, just did a quick search but you've probably already done that.
http://www.rhinoracing.com/yaw/timing.htm
Thanks for the link, not seen that one but seen others.
I am trying to complete a leak down test, I need to be able to use my pulley to set the TDC of each piston, for the hot test. I can't see my TDC mark so cant use it to get accurate piston positions. I want to do the test as fast as possible, as it gets pretty hot under the bonnet laying over the engine, and of course for accuracy. I don't want to use a dial gauge as it takes to long to set up and is hard to get the magnetic stand to reach from the nearest ferrous metal.
