can a stock bonnet be TRD-ised?
carl0s
Do you think that means the job is easier, or do you think that means it might not hold itself together when propped up? I shouldn't think it's really going to take much stress when it's down.
i'm sure i saw somewhere that offered to do this. might of been the dreaded Suprastore though! probably best to buy a new one. Wolf's sellin Matt B;s one isnt he?
yeah but it'll be Carbon Fibre or Fibreglass won't it?
i have done this before on a standard bonnet. measured and marked out the bits that need cutting, masked bonnet around area to avoid damage and using a hole cutter drilled out the corner bits first to give a nice curve line. then cut out the rest using a air saw. all the inner strengthen panel was left intacted. :thumbs:
cool :thumbs: so it wasn't all wonky around the edges then?
If i remember correctly Steve M and Matt Harwood both did theirs on standard bonnets?
And both look very good.
Dave :clap:
I made both of those bonnets from taking a trace from a TRD copy bonnet and using a holesaw and jigsaw and a good straight edge. Took about 2 hrs to make but they do need to be resprayed after to cover the cut edges. :thanks: :yawn:
Hi Steve.....nice to see your still about.
Hope alls well and when you coming back to the fold? go on you know you want to....
Dave :blahblah:
Do you have any pictures Steve?
