suprab Posted April 15, 2010 Share Posted April 15, 2010 hey all, im fitting 264 cams and changing the timing belt at the same time. should i also be replacing other things eg cam oil seals, water pump,idlers, pulleys etc??? Quote Link to comment Share on other sites More sharing options...
hodge Posted April 15, 2010 Share Posted April 15, 2010 DI'D definatly changecthe cam seals. You will have the tensioners off so if money permits I'd change them too. Only a few extra bolts to get the water pump off so like I said as above really. Quote Link to comment Share on other sites More sharing options...
nigelboyne Posted April 15, 2010 Share Posted April 15, 2010 mate not sure think you need big power ie single before you really benefit from cams, when i changed the belts i used hks pulleys and a hks timing belt, gates aux belt cause toyota list 2 belts for the supra. think the water pump should be ok unless maybe high mileage. Quote Link to comment Share on other sites More sharing options...
Nic Posted April 15, 2010 Share Posted April 15, 2010 mate not sure think you need big power ie single before you really benefit from cams You feel an increase in mid to high end power running longer duration/higher lift cams with stock turbos. Even more with ECU mapped to suit. Quote Link to comment Share on other sites More sharing options...
Graham S Posted April 15, 2010 Share Posted April 15, 2010 I'd suggest a crank pulley, or at least a dam good inspection Quote Link to comment Share on other sites More sharing options...
suprab Posted April 15, 2010 Author Share Posted April 15, 2010 cheers all, might as well change the obvious like cams seals and waterpump anyway..just askin in case there is something that gives trouble which i could prevent now. ps, single turbo and ecu already done Quote Link to comment Share on other sites More sharing options...
nigelboyne Posted April 16, 2010 Share Posted April 16, 2010 You feel an increase in mid to high end power running longer duration/higher lift cams with stock turbos. Even more with ECU mapped to suit. does that just apply for jap import or uk spec supra Quote Link to comment Share on other sites More sharing options...
Nic Posted April 16, 2010 Share Posted April 16, 2010 I'm not as familiar with UK spec Supras. However only the intake cam is slightly longer duration on the UK spec, the exhaust cams are the same as the J-spec, so it should make a noticeable difference. In256/ex264 cams are a popular set up at BPU levels. Quote Link to comment Share on other sites More sharing options...
