are the waterpump on a 2jzge and a 2jzgte the same?
luisito-awo
Not if they are exactly the same.
It's true they are identical. If you are changing it then be sure to change the small core plug at the rear of the housing. It's impossible to change it once the pump is in place and I have seen two now that have rotted through from the inside, worryingly until they fail they look pristine from the outside.
