seanfraser Posted April 15, 2010 Share Posted April 15, 2010 Hey all Want to wire a sub and amp in the boot as guessin the stock amp isn't great? Anyone wired one into the boot and if so where did you route the wiring as don't know if there's any kinda route already there because of the under parcel shelf stock one sorry just new to the ice work Thanks Quote Link to comment Share on other sites More sharing options...
tbourner Posted April 15, 2010 Share Posted April 15, 2010 I went down under the carpet on the transmission tunnel for mine, but then I had the rear seats out anyway so it was easy. There must be a route down the side under the door sills? Quote Link to comment Share on other sites More sharing options...
Wez Posted April 15, 2010 Share Posted April 15, 2010 There must be a route down the side under the door sills? Correct, plenty of room if you pop the plastic door sill off, you can go from the battery back through the firewall down to the ECU area and then back to the boot, easy peasy Quote Link to comment Share on other sites More sharing options...
seanfraser Posted April 15, 2010 Author Share Posted April 15, 2010 Thanks guys, a mates doing it and jus wanted me to find out, his dads doing me a build, any details on the stock amp under the passenger seat? Also jus bit of advice needed, should I go for amp next to sub in build or amp in middle of two subs, as not sure if tht car needs 2 subs really Quote Link to comment Share on other sites More sharing options...
