1 or 5 Wheel nuts??
Clinton
Bolt? As in a stud or a wheel nut? Your title mentions wheel nut but the thread mentions bolts?
The Supra doesn't have "bolts", it has wheel studs and nuts. If one of the studs has sheared the other 4 will have been bearing the brunt on the tension front. Of course they are designed to cope with that (one stud is enough for test conditions), but they are not designed to run like that for prolonged use or after being used outwith their intended application.
My recommendation would be to replace all 5 studs and all 5 wheel nuts.
That'll be £1000 please :D
Sorry, i should have been more specific, it is just one of the wheel nuts that has started to lose its shape so once its off i would like to replace with another nut!
All the studs and other nuts are fine so thanks for the FREE recommendation :), but do you have a spare nut for me then please ;)
Hi mate, i have some stock "nuts" if this is any use, as im pretty sure they are not compatible with after market alloys, I could be wrong though!!
Hi mate, well i need nuts with a rounded head as i have got Volk rays aftermarket alloys and all the current nuts have a rounded head that fits into the alloy. Are your ones rounded?
Do you mean rounded head or tapered as most after market alloys use a tapered seat wheel nut. I have stock toyota ones the best I can describe them is top hat shaped with a flat seat, it has an open head (you can see the wheel stud when nut is on)
Think im making sense and not confusing things further lol
i have 8 new ones on my rear staggered volks rays alloys that will fit :)
i need to change them for shorter ones as i cannot fit the centre caps the fronts are a perfect fit (same size)with centre caps fitted:), the rears would be if i did not have centre caps:D
Thank you very much for the offer mate but yes you are confusing me :D
I think i will try the man above since he has the same alloys so would be a safer bet!
Thanks
Hi mate,
Sorry i dont see how having centre caps will stop wheel nuts fitting?? How big are these bolts :)
Are these the alloys you have as these are the alloys i have...
http://www.mkivsupra.net/vbb/attachment.php?attachmentid=106180&d=1267776848
Thanks
Clinton
Hi mate,
Thanks
Clinton
hi Clinton
my wheels are staggered on the rears , the nuts will fit your wheels i will take a photo for you on tuesday , i bought 16 put them on the front and they fit fine with centre caps ,they fit fine on the back but are stoping me puting on my centre caps
here are my wheels cheers paul[ATTACH]108483[/ATTACH]
[ATTACH]108484[/ATTACH]
