devan Posted April 14, 2010 Share Posted April 14, 2010 Is there any way if i can tell if my car has ABS? Its a 1994 JSpec N/A. Ive read a few n/a's do have it and a few dont, but how do you know lol. There is no ABS light when i turn the ignition on, but this is because there is no bulb in the holder for the ABS. Is there any other way i can check, without having to put a bulb in the ABS holder. Cheers, Ash. Link to comment Share on other sites More sharing options...
Animal Posted April 14, 2010 Share Posted April 14, 2010 Go for a drive then stamp on the brakes REALLY HARD. If the pedal judders like an epileptic in a strobe light factory, then you have ABS. If you lock all four wheels and slide sideways into a bus shelter, you probably don't. Link to comment Share on other sites More sharing options...
TooColdToDrive Posted April 14, 2010 Share Posted April 14, 2010 ^I found my first sig quote! Link to comment Share on other sites More sharing options...
Attero Posted April 14, 2010 Share Posted April 14, 2010 I found a box that says ABS on it attached to the headunit behind the dash... if that counts... and if you can bothered to rip all the dash out. Might be something behind there. Link to comment Share on other sites More sharing options...
AlexM Posted April 14, 2010 Share Posted April 14, 2010 Open the bonnet and see if you have an ABS unit.. Link to comment Share on other sites More sharing options...
devan Posted April 14, 2010 Author Share Posted April 14, 2010 There is an ABS box behind the dash, but i always assumed that the word 'ABS' printed on the plastic box was what the plastic was made from lol: ABS, Acrylonitrile-Butadiene-Styrene ABS is a "polymericed alloy" of the tree materials acrylonitrile, butadiene and styrene. The material is located under the group styrene plastic. Styrene plastics are in volume one of the most used plastics. Link to comment Share on other sites More sharing options...
michael Posted April 14, 2010 Share Posted April 14, 2010 There is an ABS box behind the dash, but i always assumed that the word 'ABS' printed on the plastic box was what the plastic was made from lol: ABS, Acrylonitrile-Butadiene-Styrene ABS is a "polymericed alloy" of the tree materials acrylonitrile, butadiene and styrene. The material is located under the group styrene plastic. Styrene plastics are in volume one of the most used plastics. I hope you're right because I get quite a lot of pleasure from licking my LSD. Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted April 14, 2010 Share Posted April 14, 2010 I hope you're right because I get quite a lot of pleasure from licking my LSD. me too Link to comment Share on other sites More sharing options...
devan Posted April 14, 2010 Author Share Posted April 14, 2010 Cheers AlexM, it doesnt have an ABS unit, so no ABS lol. Link to comment Share on other sites More sharing options...
