Wiring Help???
Guest GTS94
Guest GTS94
Hello,
Is there anywhere behind the instrument panel (3 block connectors) that i can get an RPM signal feed from?
If so does anyone know which wire it is, or if somebody has a pinout for the block connectors?
Btw. Its a 93 j-spec N/A
Thanks!
Guest GTS94
I think the rpm pins pulse differently between the dash and ECU. Do you need a -ve or +ve pulse?
Not sure Homer,
Im wiring up an Auto gauge tachometer so im guessing that i need the same rpm signal that the oem tachometer has.
