What colour caliper?
a98pmalcolm
What colour?
58 members have voted
  1. 1. What colour?
    • Blue
      6
    • Red
      10
    • Black
      20
    • Silver
      5
    • Carbon Grey
      17
How easy is it to re-paint the calipers?Might consider re-doing all mine
Easy peezy.
Remove inc pads, clean, paint, refit,+ bleed brakes then add new decales from ebay:)
Just make sure you clamp off your brake pipes on the rubber hose to stop the brake fluid draining out!
Heat proof paint is best too.
good luck!
easy, do 1 wheel at a time, get a small ish brush, and just paint it slowly, inside the edges, around the back and use a 1" for a level finish on the main front part. Or you can open the callipers like i did to get every bit covered:) if your not to familiar with callipers, leave them closed, mask the discs of to:) try not to touch the brake pad as it will look a bit messy.
1 bolt at the bottom rear to open the calliper, when putting it back down use a rubber handled bar to push the piston back, and open the resivor just incase:)
have to strip mine down and paint again as my first go was messy
