seamybaby Posted April 12, 2010 Share Posted April 12, 2010 i want a quik and easy way to disable my supra,by removing a certain fuse or relay....can someone point me in the right direction please.........i do have the usual security devices fitted just want another deterrent........... Link to comment Share on other sites More sharing options...
patrikbrunt Posted April 12, 2010 Share Posted April 12, 2010 You can remove the 2 EFI relays in the relay box under the bonnet... a bit of a pain if your thinking of doing it every time though??! Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 12, 2010 Share Posted April 12, 2010 Wire the ecu to fuel pump controller through the cigar lighter. Done properly the car will only run with the fag lighter pushed in. Link to comment Share on other sites More sharing options...
