robin Posted April 12, 2010 Share Posted April 12, 2010 While driving yesterday the big red light in the centre of the dial came on. I pulled over, checked all the doors, boot and handbrake etc but to no avail. After stopping the engine and restarting it the light is off but comes on and stays on as soon as the brake pedal is pressed. The brake fluid was on max so I have topped it up so it is now slightly over max and the light still comes on as above. Disconnecting the little sensor on the fluid reservoir makes no difference. I didn’t check the error codes as it was starting to get dark but I will check for a code as soon as I can. Does anyone have any ideas what the problem might be? The car drives and stops fine. Quote Link to comment Share on other sites More sharing options...
Thorin Posted April 12, 2010 Share Posted April 12, 2010 Try cleaning the connector? Quote Link to comment Share on other sites More sharing options...
ilicos Posted April 12, 2010 Share Posted April 12, 2010 Edited because I did not read properly. Have you had the dash out recently? Quote Link to comment Share on other sites More sharing options...
robin Posted April 12, 2010 Author Share Posted April 12, 2010 Edited because I did not read properly. Have you had the dash out recently? The dash has been out in the past but not for over a year. Quote Link to comment Share on other sites More sharing options...
robin Posted April 12, 2010 Author Share Posted April 12, 2010 Try cleaning the connector? The connector that plugs in to the reservoir? Would it normally log an error or light up the MIL if it was just unplugged? Quote Link to comment Share on other sites More sharing options...
dangerous brain Posted April 12, 2010 Share Posted April 12, 2010 Is there a brake pad warning sensor on the supra? Quote Link to comment Share on other sites More sharing options...
caseys Posted April 12, 2010 Share Posted April 12, 2010 Check if you've goT a brake light out as the symptoms you describe are exactly what I had when my offside rear brakelight bulb died Quote Link to comment Share on other sites More sharing options...
Thorin Posted April 12, 2010 Share Posted April 12, 2010 Check if you've goT a brake light out as the symptoms you describe are exactly what I had when my offside rear brakelight bulb died Ooh yes, forgot about that. Yes I remember same when mine went too. Quote Link to comment Share on other sites More sharing options...
dangerous brain Posted April 12, 2010 Share Posted April 12, 2010 ROFL I remember that as well LOL. Quote Link to comment Share on other sites More sharing options...
robin Posted April 12, 2010 Author Share Posted April 12, 2010 I didnt think to check the brake lights. I'll have a look when I get home. Quote Link to comment Share on other sites More sharing options...
snake Posted April 12, 2010 Share Posted April 12, 2010 i had the same problem ,one end of the filament in the brake light bulb was loose so the dash light would come when the contact was broken if it went over a bump. Quote Link to comment Share on other sites More sharing options...
