Electrical help please
evinX
Hey everyone, ive got 2 little problems on the supra that need to be sorted, my only problem is, i dont know what the cause could be. Here they are
*Auto shifter + speedo cluster illumination
*Passenger side headlight fog to be fixed (all other front lights work just fine)
I know by law we dont need front fogs, but id like it to work propely. What could be the cause of these 2 problems??
Thanks, Kevin
Hi mate, yup i had time and tried that button on the dash that turns around, no luck, fog fuse in the engine bay are fine, some seem to be missing:S hopes thats normal??
Now ive discovered both front fogs arnt working:( ahhhhh this has been bugging me for a few months, but its now time to get this sorted, any more ideas will be of great help
thanks, Kev
It's normal for some fuses to be "missing" in the fuse box (mine certainly has, other specs may vary): they're just unused slots IIRC. If the bulbs are OK but aren't getting any power (test connections with a voltmeter to confirm), then suspect relays (if there are any in the circuit) or the switch. Not sure how best to track it back other than following the loom from the headlight cluster though.
I reckon it has to be the relay, my dad did some tracing a while back, removed my fuse box to check even further but nothing:(
  • 5 weeks later...
